Sony Xperia ZL Battery Replacement
  1. Sony Xperia ZL Battery Replacement, Battery: step 1, image 1 of 1
    • Place the phone face down.
  2. Sony Xperia ZL Battery Replacement: step 2, image 1 of 1
    • At the bottom of the phone will be a cover that flips open. A sticker will be under and when the sticker is peeled back, two screws will be revealed. Use a JIS J00 screw head to unscrew.
  3. Sony Xperia ZL Battery Replacement: step 3, image 1 of 1
    • Once the two screws have been removed. Take the prying tool to pry off the back cover of the phone. Next take a JIS J00 screwhead and unscrew the 5 screws that are located in the photo.
  4. Sony Xperia ZL Battery Replacement: step 4, image 1 of 1
    • After the screws have been taken out, carefully disconnect the 7 indicated connectors using a small plastic opening tool or spudger.
    • Metal spudgers can puncture an unprotected battery, potentially causing a fire. When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
  5. Sony Xperia ZL Battery Replacement: step 5, image 1 of 1
    • The last connector is located under the black sticker. Peel back the black sticker and disconnect the last connector.
  6. Sony Xperia ZL Battery Replacement: step 6, image 1 of 1
    • Once all the connectors have been disconnected. You will want to use a small prying tool to pry out the back camera and all its components from the phone.
  7. Sony Xperia ZL Battery Replacement: step 7, image 1 of 1
    • Remove the electrical panel with a plastic opening tool.
  8. Sony Xperia ZL Battery Replacement: step 8, image 1 of 1
    • Take a small plastic prying tool and pry out the battery of the phone. The battery has adhesive tape that connects it to the phone which makes it difficult to pry out. Make sure to try prying from different angles of the battery.
    • Use a plastic prying tool when taking out the battery because any puncture within the battery could cause a fire.
3 other people completed this guide.
Liam Kanaley
433 Reputation
3 Guides authored
UMass Dartmouth, Team 1-7, Bhusal Fall 2015 Member of UMass Dartmouth, Team 1-7, Bhusal Fall 2015
UMASSD-BHUSAL-F15S1G7
3 Members
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 9
All Time: 1,762
