Sony ZS-RS60BT Repair Battery Replacement
  1. Sony ZS-RS60BT Repair Battery Replacement, Battery: step 1, image 1 of 2 Sony ZS-RS60BT Repair Battery Replacement, Battery: step 1, image 2 of 2
    • Locate back panel.
    • Put firm downward pressure on the panel until it slides off.
  2. Sony ZS-RS60BT Repair Battery Replacement: step 2, image 1 of 1
    • If the batteries are corroded, it is recommended to wear gloves when removing the batteries.
    • From the positive side of the battery, push it to the negative side and lift up.
    • Repeat for each battery until the compartment is empty.
Sarah Hamrin
1 Reputation
2 Guides authored
Baylor, Team 8-2, Whitney Spring 2017 Member of Baylor, Team 8-2, Whitney Spring 2017
BU-WHITNEY-S17S8G2
4 Members
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 664
