Sophix TAB-730g Battery Replacement
  1. Sophix TAB-730g Battery Replacement, Battery: step 1, image 1 of 1
    • Remove the back cover to gain access to the mother board.
    • Unscrew, with a 000 Philip's screwdriver, the 3.547 mm long screw located at the bottom of your tablet.
  2. Sophix TAB-730g Battery Replacement: step 2, image 1 of 1
    • Firmly slide the cover in the direction indicated by the arrow, away from the ports, with your hand to remove the back cover.
  3. Sophix TAB-730g Battery Replacement: step 3, image 1 of 1
    • Desolder the two wires connecting the battery to the mother board.
  4. Sophix TAB-730g Battery Replacement: step 4, image 1 of 1
    • Gently pry the battery off the back of the device using some force.
    • There is adhesive keeping the battery attached so a decent amount of force may need to be applied.
2 other people completed this guide.
JT Hiquet
333 Reputation
3 Guides authored
IUPUI, Team 2-3, Harley Fall 2016 Member of IUPUI, Team 2-3, Harley Fall 2016
IUPUI-HARLEY-F16S2G3
4 Members
6 Guides authored
One Comment
[|how do you know if the problem is or is not the battery?]
Don Taylor - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 395
