Sophix TAB-730g Speakers Replacement
  1. Sophix TAB-730g Speakers Replacement, Speakers: step 1, image 1 of 1
    • Remove the back panel of the tablet so that you can access the tablet’s motherboard.
    • First, using the #000 Phillips screwdriver, remove the screws located at the bottom of the tablet.
  2. Sophix TAB-730g Speakers Replacement: step 2, image 1 of 1
    • After you have removed the screws from the bottom of the tablet, you can now slide the cover off. To do this, place your hand on the panel and firmly slide the panel in the direction that the arrow indicates.
  3. Sophix TAB-730g Speakers Replacement: step 3, image 1 of 1
    • Next, find the wires that connect the speakers to the motherboard. (Follow the red marker indicated in the image.) To remove these, you will use the soldering iron.
  4. Sophix TAB-730g Speakers Replacement: step 4, image 1 of 1
    • Turn the device so that the speakers are at the top.
    • Locate the leads that connect the logic board to the speakers.
    • Starting from the left, you will use the solder iron to desolder the first four leads.
    • Now you are ready to remove the old, and insert the new speakers.
JT Hiquet
333 Reputation
3 Guides authored
IUPUI, Team 2-3, Harley Fall 2016 Member of IUPUI, Team 2-3, Harley Fall 2016
IUPUI-HARLEY-F16S2G3
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 191
