SoundBot SB571 Speaker Grille
  1. SoundBot SB571 Speaker Grille, Speaker Grille: step 1, image 1 of 1
    • Before disassembling the speaker, make sure it is powered off.
    • Place the speaker on a flat surface.
    • Take your blue plastic opening tool and remove the plastic cover.
  2. SoundBot SB571 Speaker Grille: step 2, image 1 of 3 SoundBot SB571 Speaker Grille: step 2, image 2 of 3 SoundBot SB571 Speaker Grille: step 2, image 3 of 3
    • Orient the speaker so that the top is facing up.
    • Using your Phillips PH0 screwdriver unscrew the 14, 0.6cm screws from the device along the speaker grille.
  3. SoundBot SB571 Speaker Grille: step 3, image 1 of 2 SoundBot SB571 Speaker Grille: step 3, image 2 of 2
    • Reorient the speaker so the grille is facing you.
    • Using the blue plastic opening tool, prop open the metal grille.
    • Now the speaker grille is completely removed from the device and it can be replaced.
2 other people completed this guide.
Yana
645 Reputation
2 Guides authored
USF Tampa, Team 2-50, Cagle Spring 2016 Member of USF Tampa, Team 2-50, Cagle Spring 2016
USFT-CAGLE-S16S2G50
4 Members
2 Guides authored
One Comment
Sir my soundbot sb571 one side sound doesnot work how could i do for its repairing.
Ram Meena - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 17
All Time: 1,638
