Spark Test
  1. Spark Test, Safety precautions: step 1, image 1 of 2 Spark Test, Safety precautions: step 1, image 2 of 2
    • Flip the power switch into the STOP position.
    • Make sure the engine is cool to the touch before proceeding.
  2. Spark Test, Remove the muffler cover: step 2, image 1 of 2 Spark Test, Remove the muffler cover: step 2, image 2 of 2
    • Use a T27 Torx screwdriver to remove the two screws securing the bottom of the muffler cover to the motor.
  3. Spark Test: step 3, image 1 of 3 Spark Test: step 3, image 2 of 3 Spark Test: step 3, image 3 of 3
    • Tilt the muffler cover up, hinging along the top edge, until it can be removed from the motor cover.
    • Remove the muffler cover.
  4. Spark Test: step 4, image 1 of 2 Spark Test: step 4, image 2 of 2
    • Pull the spark plug boot straight off of the spark plug.
  5. Spark Test, Connect the spark tester: step 5, image 1 of 2 Spark Test, Connect the spark tester: step 5, image 2 of 2
    • Connect the spark plug boot to the left terminal of the ignition checker.
  6. Spark Test: step 6, image 1 of 1
    • Connect the ignition checker alligator clip to a metal surface on the motor to ground the accessory cord.
  7. Spark Test: step 7, image 1 of 1
    • Set the spark gap to 6 mm by turning the spark gap adjustment knob counterclockwise.
    • Do not set the spark gap unnecessarily wide—a high voltage may damage the ignition coil.
  8. Spark Test: step 8, image 1 of 1
    • Flip the power switch into the ON position.
  9. Spark Test: step 9, image 1 of 3 Spark Test: step 9, image 2 of 3 Spark Test: step 9, image 3 of 3
    • Hold the spark tester by the handle on the bottom. Do not touch the terminals or spark window while the test is being conducted.
    • Watch for a spark in the spark window while a second person pulls the starter to crank the engine.
    • Consult the ignition checker instruction manual to troubleshoot the device.
Sam Omiotek
94,078 Reputation
290 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 15
All Time: 581
