Speaker Bose SoundDock Motherboard Replacement
  1. Speaker Bose SoundDock Motherboard Replacement, Bose SoundDock Motherboard: step 1, image 1 of 2 Speaker Bose SoundDock Motherboard Replacement, Bose SoundDock Motherboard: step 1, image 2 of 2
    • Remove the battery by pressing your finger down on the center button and twisting it counter-clockwise.
    • Remove battery and set it aside.
  2. Speaker Bose SoundDock Motherboard Replacement: step 2, image 1 of 1
    • Use a plastic scraper to remove the rubber gasket from the bottom of speaker system and set it aside.
  3. Speaker Bose SoundDock Motherboard Replacement: step 3, image 1 of 1
    • Use a standard sized Phillips Screwdriver to remove the four screws on the bottom of the speaker system.
  4. Speaker Bose SoundDock Motherboard Replacement: step 4, image 1 of 1
    • Using a smaller flat head screw driver, unscrew the semi-circle plate from bottom to expose the motherboard.
    • Once the components are unscrewed, the plastic dock frame may fall out.
  5. Speaker Bose SoundDock Motherboard Replacement: step 5, image 1 of 1
    • Gently pull both ribbon cables out of the motherboard.
  6. Speaker Bose SoundDock Motherboard Replacement: step 6, image 1 of 1
    • Replace it with new motherboard by plugging in the thinner wire into the small slot, and the larger wire into the wider slot.
    • Reverse steps 1 through 4 to reassemble dock.
Dalton Alexandre
123 Reputation
1 Guide authored
Cal Poly, Team 24-5, Green Winter 2015 Member of Cal Poly, Team 24-5, Green Winter 2015
CPSU-GREEN-W15S24G5
3 Members
4 Guides authored
One Comment
Where can you buy the motherboard?
Steffen Jensen - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 3,285
