Zenbre SoundBank Z3 Speaker Grill Replacement
  1. Zenbre SoundBank Z3 Speaker Grill Replacement, Bottom Cover: step 1, image 1 of 2 Zenbre SoundBank Z3 Speaker Grill Replacement, Bottom Cover: step 1, image 2 of 2
    • Power off the SoundBank Z3.
    • Turn over the device.
    • Peel the silicone feet up to remove.
    • No extra adhesive is needed to reapply the feet as long as the sticky side is not touched.
  2. Zenbre SoundBank Z3 Speaker Grill Replacement: step 2, image 1 of 1
    • Remove all eight of the 11 mm Phillips screws from the bottom of the device.
  3. Zenbre SoundBank Z3 Speaker Grill Replacement: step 3, image 1 of 2 Zenbre SoundBank Z3 Speaker Grill Replacement: step 3, image 2 of 2
    • Remove the bottom panel speaker using an iFixit opening tool.
  4. Zenbre SoundBank Z3 Speaker Grill Replacement, Motherboard Cover: step 4, image 1 of 3 Zenbre SoundBank Z3 Speaker Grill Replacement, Motherboard Cover: step 4, image 2 of 3 Zenbre SoundBank Z3 Speaker Grill Replacement, Motherboard Cover: step 4, image 3 of 3
    • Remove the four 4.5 mm silver Phillips screws that secure the plastic panel covering the motherboard.
    • Remove the plastic panel.
  5. Zenbre SoundBank Z3 Speaker Grill Replacement, Speaker Grill: step 5, image 1 of 3 Zenbre SoundBank Z3 Speaker Grill Replacement, Speaker Grill: step 5, image 2 of 3 Zenbre SoundBank Z3 Speaker Grill Replacement, Speaker Grill: step 5, image 3 of 3
    • Remove the three silver Phillips screws from the plastic ring that holds the speaker in place.
    • Be careful not to rip out the speaker while taking out the screws
    • The same steps can be done on the other side of the speaker
  6. Zenbre SoundBank Z3 Speaker Grill Replacement: step 6, image 1 of 3 Zenbre SoundBank Z3 Speaker Grill Replacement: step 6, image 2 of 3 Zenbre SoundBank Z3 Speaker Grill Replacement: step 6, image 3 of 3
    • First, remove the speaker from the motherboard, then remove the ring that held the speaker in place.
    • These are the joints that need to be soldered. Follow this guide link to help you remove the wires from the motherboard.
    • How To Solder and Desolder Connections
  7. Zenbre SoundBank Z3 Speaker Grill Replacement: step 7, image 1 of 2 Zenbre SoundBank Z3 Speaker Grill Replacement: step 7, image 2 of 2
    • With the plastic ring removed, the speaker should slide out easily.
    • Be careful not remove other components in the speaker
    • This will expose the speaker grill
  8. Zenbre SoundBank Z3 Speaker Grill Replacement: step 8, image 1 of 3 Zenbre SoundBank Z3 Speaker Grill Replacement: step 8, image 2 of 3 Zenbre SoundBank Z3 Speaker Grill Replacement: step 8, image 3 of 3
    • Now that the speaker has been removed, the plastic grill should be visible.
    • With a little bit of force they can be pushed out.
2 other people completed this guide.
Luc Josue Pierre Louis
183 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 7
All Time: 639
