Speed Switch
  1. Speed Switch, Switch: step 1, image 1 of 2 Speed Switch, Switch: step 1, image 2 of 2
    • Use a phillips head screwdriver to unscrew the following 8 screws:
    • One 24mm Phillips screw
    • Six 16mm Phillips screws
    • One 9mm Phillips screw
    • Turn the drill to the other side and unscrew the marked screw using the same phillips head screwdriver. Place it with the other removed screws.
    • Keep all screws organized on a magnetic mat after removal.
  2. Speed Switch: step 2, image 1 of 3 Speed Switch: step 2, image 2 of 3 Speed Switch: step 2, image 3 of 3
    • Carefully remove the plastic drill casing by pulling it apart.
    • When separating the drill casing, the black plastic speed switch covering will be removed from the drill automatically.
  3. Speed Switch: step 3, image 1 of 2 Speed Switch: step 3, image 2 of 2
    • Gently remove the orange plastic speed switch from the drill. It is located right above the motor.
3 other people completed this guide.
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 10
All Time: 1,009
