Spin Master Boxer Remote Trigger Buttons Replacement
  1. Spin Master Boxer Remote Trigger Buttons Replacement, Remote Trigger Buttons: step 1, image 1 of 1
    • Lay the remote flat on your work space, with joysticks facing you.
  2. Spin Master Boxer Remote Trigger Buttons Replacement: step 2, image 1 of 1
    • Remove both joysticks by gripping under circular knob and gently pulling towards you.
    • The joysticks should detach without much effort.
  3. Spin Master Boxer Remote Trigger Buttons Replacement: step 3, image 1 of 1
    • Use the Phillips #00 Screwdriver to remove 4mm screw on the center battery panel.
    • Remove the batteries from the remote and set it to side.
    • Use the same screwdriver to remove all four 4mm screws on back panel.
  4. Spin Master Boxer Remote Trigger Buttons Replacement: step 4, image 1 of 2 Spin Master Boxer Remote Trigger Buttons Replacement: step 4, image 2 of 2
    • Insert the Jimmy in between the top panel and the bottom panel.
    • Gently use the Jimmy to separate both plastic panels from each other.
    • Pull the panels apart and set bottom piece on workbench.
  5. Spin Master Boxer Remote Trigger Buttons Replacement: step 5, image 1 of 2 Spin Master Boxer Remote Trigger Buttons Replacement: step 5, image 2 of 2
    • Pinch the trigger between index finger and thumb, and lift up, away from circuit board.
    • Inspect the square button attached to circuit board to ensure functionality. If there is an issue with connection, a new circuit boards may be required.
Lauren Roide
739 Reputation
5 Guides authored
Cal Poly, Team S1-G1, Maness Spring 2019 Member of Cal Poly, Team S1-G1, Maness Spring 2019
CPSU-MANESS-S19S1G1
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 14
All Time: 864
