Spin Master Boxer Robot Battery Replacement
  1. Spin Master Boxer Robot Battery Replacement, Robot Screen: step 1, image 1 of 1
    • Set Spin Master Boxer on your workspace so that the bottom panel faces upwards.
  2. Spin Master Boxer Robot Battery Replacement: step 2, image 1 of 1
    • Using a Phillips #00 screw driver, unscrew the four 4mm screws in each corner of the bottom panel.
  3. Spin Master Boxer Robot Battery Replacement: step 3, image 1 of 1
    • Carefully remove the bottom panel of the Spin Master Boxer by lifting up, away from the main body of robot.
  4. Spin Master Boxer Robot Battery Replacement: step 4, image 1 of 2 Spin Master Boxer Robot Battery Replacement: step 4, image 2 of 2
    • While holding onto the axels of the wheels, gently pull the top panel of the robot away from its body.
    • Be aware when removing the panel that multiple wires connect it to the body of the Spin Master Boxer.
  5. Spin Master Boxer Robot Battery Replacement: step 5, image 1 of 1
    • Remove the plastic screen from the body of the robot. It should come off easily as it is not attached by anything.
  6. Spin Master Boxer Robot Battery Replacement, Robot Battery: step 6, image 1 of 2 Spin Master Boxer Robot Battery Replacement, Robot Battery: step 6, image 2 of 2
    • Lift the top panel away from the main body of the robot to expose the yellow battery.
  7. Spin Master Boxer Robot Battery Replacement: step 7, image 1 of 1
    • Insert index finger in between battery and plastic shell of robot, and push battery out of the battery holder toward the wire.
  8. Spin Master Boxer Robot Battery Replacement: step 8, image 1 of 1
2 other people completed this guide.
Lauren Roide
739 Reputation
5 Guides authored
Cal Poly, Team S1-G1, Maness Spring 2019 Member of Cal Poly, Team S1-G1, Maness Spring 2019
CPSU-MANESS-S19S1G1
4 Members
10 Guides authored
3 Comments
Any tips on where to buy a replacement battery?
Chad Laughlin - Reply
In fact it’s easy, was able to put 1000 mah Lipo 952540 with a little stretching of battery plastic holder
Anton Litvinov - Reply
can we replace boxer’s USB slot?
Buchukoy Jimenez - Reply
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 30
All Time: 2,176
