Spin Master Boxer Robot Screen Replacement
  1. Spin Master Boxer Robot Screen Replacement, Robot Screen: step 1, image 1 of 1
    • Set Spin Master Boxer on your workspace so that the bottom panel faces upwards.
  2. Spin Master Boxer Robot Screen Replacement: step 2, image 1 of 1
    • Using a Phillips #00 screw driver, unscrew the four 4mm screws in each corner of the bottom panel.
  3. Spin Master Boxer Robot Screen Replacement: step 3, image 1 of 1
    • Carefully remove the bottom panel of the Spin Master Boxer by lifting up, away from the main body of robot.
  4. Spin Master Boxer Robot Screen Replacement: step 4, image 1 of 2 Spin Master Boxer Robot Screen Replacement: step 4, image 2 of 2
    • While holding onto the axels of the wheels, gently pull the top panel of the robot away from its body.
    • Be aware when removing the panel that multiple wires connect it to the body of the Spin Master Boxer.
  5. Spin Master Boxer Robot Screen Replacement: step 5, image 1 of 1
    • Remove the plastic screen from the body of the robot. It should come off easily as it is not attached by anything.
Lauren Roide
739 Reputation
5 Guides authored
Cal Poly, Team S1-G1, Maness Spring 2019 Member of Cal Poly, Team S1-G1, Maness Spring 2019
CPSU-MANESS-S19S1G1
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 485
