Spin Master Hatchimal Draggle Wheels Replacement
  1. Spin Master Hatchimal Draggle Wheels Replacement, Plastic Wing Replacement: step 1, image 1 of 1
    • lay the Hatchimal on its side.
  2. Spin Master Hatchimal Draggle Wheels Replacement: step 2, image 1 of 1
    • Using the plastic opening tool, push in on the purple clip.
  3. Spin Master Hatchimal Draggle Wheels Replacement: step 3, image 1 of 1
    • Pull the wing off of the hatchimal.
    • The wing should come off with little resistance.
  4. Spin Master Hatchimal Draggle Wheels Replacement, Fur Replacement: step 4, image 1 of 2 Spin Master Hatchimal Draggle Wheels Replacement, Fur Replacement: step 4, image 2 of 2
    • Cut the fur retaining zip-tie with a pair of scissors.
  5. Spin Master Hatchimal Draggle Wheels Replacement: step 5, image 1 of 2 Spin Master Hatchimal Draggle Wheels Replacement: step 5, image 2 of 2
    • Lift the fur up until it can't go further.
  6. Spin Master Hatchimal Draggle Wheels Replacement: step 6, image 1 of 3 Spin Master Hatchimal Draggle Wheels Replacement: step 6, image 2 of 3 Spin Master Hatchimal Draggle Wheels Replacement: step 6, image 3 of 3
    • Use the spudger tool to push up on the black clip to free it.
    • Pull the clip out.
  7. Spin Master Hatchimal Draggle Wheels Replacement: step 7, image 1 of 3 Spin Master Hatchimal Draggle Wheels Replacement: step 7, image 2 of 3 Spin Master Hatchimal Draggle Wheels Replacement: step 7, image 3 of 3
    • Lift fur up to reveal the next set of clips.
    • Insert a spudger to push up on the black clip to free it.
    • Pull out the clip.
  8. Spin Master Hatchimal Draggle Wheels Replacement: step 8, image 1 of 2 Spin Master Hatchimal Draggle Wheels Replacement: step 8, image 2 of 2
    • Lift the fur up and over the Hatchimals Head.
    • Remove the six 12mm Phillips #00 screws from then body.
  9. Spin Master Hatchimal Draggle Wheels Replacement: step 9, image 1 of 2 Spin Master Hatchimal Draggle Wheels Replacement: step 9, image 2 of 2
    • Pull the casing apart.
    • Remove the yellow speaker cable.
  10. Spin Master Hatchimal Draggle Wheels Replacement: step 10, image 1 of 3 Spin Master Hatchimal Draggle Wheels Replacement: step 10, image 2 of 3 Spin Master Hatchimal Draggle Wheels Replacement: step 10, image 3 of 3
    • Remove the three 7mm Phillips #00 screws from the head.
    • Remove the wheel base and the circuit board carefully not to damage the spring.
  11. Spin Master Hatchimal Draggle Wheels Replacement: step 11, image 1 of 2 Spin Master Hatchimal Draggle Wheels Replacement: step 11, image 2 of 2
    • Push the six black fur clips out using the spudger.
    • Remove the fur completely.
  12. Spin Master Hatchimal Draggle Wheels Replacement, Wheel Replacement: step 12, image 1 of 2 Spin Master Hatchimal Draggle Wheels Replacement, Wheel Replacement: step 12, image 2 of 2
    • Lift up and remove the light blue plastic casing.
  13. Spin Master Hatchimal Draggle Wheels Replacement: step 13, image 1 of 2 Spin Master Hatchimal Draggle Wheels Replacement: step 13, image 2 of 2
    • Remove the six 7mm Phillips #00 screws.
  14. Spin Master Hatchimal Draggle Wheels Replacement: step 14, image 1 of 2 Spin Master Hatchimal Draggle Wheels Replacement: step 14, image 2 of 2
    • Remove the purple plastic casing. It should come off with little resistance.
    • Remove the wheel.
2 other people completed this guide.
Humaid Alhajri
115 Reputation
1 Guide authored
USF Tampa, Team S1-G5, Nance Spring 2018 Member of USF Tampa, Team S1-G5, Nance Spring 2018
USFT-NANCE-S18S1G5
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 1,154
