Spiral Bound Notebook Cover Replacement
  1. Spiral Bound Notebook Cover Replacement, Cover: step 1, image 1 of 2 Spiral Bound Notebook Cover Replacement, Cover: step 1, image 2 of 2
    • Use a binder clip on either end to hold the paper block together, excluding the damaged cover.
  2. Spiral Bound Notebook Cover Replacement: step 2, image 1 of 3 Spiral Bound Notebook Cover Replacement: step 2, image 2 of 3 Spiral Bound Notebook Cover Replacement: step 2, image 3 of 3
    • Uncoil the free end of the spiral.
  3. Spiral Bound Notebook Cover Replacement: step 3, image 1 of 3 Spiral Bound Notebook Cover Replacement: step 3, image 2 of 3 Spiral Bound Notebook Cover Replacement: step 3, image 3 of 3
    • Push the spiral end back through the binding hole and pull it out.
  4. Spiral Bound Notebook Cover Replacement: step 4, image 1 of 1
    • Repeat previous step until spiral is removed.
  5. Spiral Bound Notebook Cover Replacement: step 5, image 1 of 1
    • Take the damaged cover and place it over the cardstock, aligning them at the edges.
  6. Spiral Bound Notebook Cover Replacement: step 6, image 1 of 3 Spiral Bound Notebook Cover Replacement: step 6, image 2 of 3 Spiral Bound Notebook Cover Replacement: step 6, image 3 of 3
    • Trace the cover edges.
  7. Spiral Bound Notebook Cover Replacement: step 7, image 1 of 2 Spiral Bound Notebook Cover Replacement: step 7, image 2 of 2
    • Trace the cover binding holes.
  8. Spiral Bound Notebook Cover Replacement: step 8, image 1 of 3 Spiral Bound Notebook Cover Replacement: step 8, image 2 of 3 Spiral Bound Notebook Cover Replacement: step 8, image 3 of 3
    • Using a hole punch, punch out the traced holes on the cardstock sheet.
  9. Spiral Bound Notebook Cover Replacement: step 9, image 1 of 3 Spiral Bound Notebook Cover Replacement: step 9, image 2 of 3 Spiral Bound Notebook Cover Replacement: step 9, image 3 of 3
    • Cut off the traced edges on the cardstock sheet.
  10. Spiral Bound Notebook Cover Replacement: step 10, image 1 of 2 Spiral Bound Notebook Cover Replacement: step 10, image 2 of 2
    • Without removing the binding clip, open it and slide the cardstock onto the paper block while making sure their holes aligned.
  11. Spiral Bound Notebook Cover Replacement: step 11, image 1 of 3 Spiral Bound Notebook Cover Replacement: step 11, image 2 of 3 Spiral Bound Notebook Cover Replacement: step 11, image 3 of 3
    • Perform Steps 1 through 4 in reverse to complete the replacement.
To reassemble your device, follow instructions 1 - 4 in reverse order.
Abel Mbaziira
220 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 35
Past 30 Days: 142
All Time: 4,938
