Sprout Channel Cubby Battery Replacement
  1. Sprout Channel Cubby Battery Replacement, Dissasemble the device: step 1, image 1 of 2 Sprout Channel Cubby Battery Replacement, Dissasemble the device: step 1, image 2 of 2
    • Use an opening tool to push in and release sixteen small plastic clips around the edge of the case. As the clips are released, gradually pry the case apart.
    • It is easiest to start on the corners.
  2. Sprout Channel Cubby Battery Replacement, Battery: step 2, image 1 of 2 Sprout Channel Cubby Battery Replacement, Battery: step 2, image 2 of 2
    • Remove the black electrical tape over the ribbon connector.
    • Remove the ribbon connector over the battery.
    • Make sure to be careful of the ribbon connector while working on the device.
  3. Sprout Channel Cubby Battery Replacement: step 3, image 1 of 1
    • Next you must heat up the battery to help weaken the adhesive connecting the battery to the device.
  4. Sprout Channel Cubby Battery Replacement: step 4, image 1 of 1
    • Once this is done start to pry the battery away from the device carefully. It helps to start at the corners and move inward.
  5. Sprout Channel Cubby Battery Replacement: step 5, image 1 of 2 Sprout Channel Cubby Battery Replacement: step 5, image 2 of 2
    • Once you remove the battery from the device it is still connected by three wires: red, black, and, white. It is important to remember the order they are in when reconnecting the new battery.
3 other people completed this guide.
jasen biggins
741 Reputation
5 Guides authored
USF Tampa, Team 14-101, Meier Fall 2015 Member of USF Tampa, Team 14-101, Meier Fall 2015
USFT-MEIER-F15S14G101
4 Members
12 Guides authored
7 Guide Comments
Ours is only 6 months old. It only works when it stays plugged in. Battery is bad?
Rachel - Reply Share
I had the same problem, only played while plugged in and would not charge.. I found that the battery wires while appearing tight one wire had broken inside the wire insulation at the solder pad on the main board. When I redid the connection it charges, and works well. 8/11/16
larrywb135 - Share
My grand daughters won't come on, should I take it to an electronic store?. I don't want to try and pry it open, for fear I may make it worse, she loves her tablet, and it is very helpful for her with school, she's had it 2 years and I put it away for about 8 month, for going on line, without permission, I gave it back in Sept. Now its not charging or coming on. Thank you.Deborah
jacksondebo2010 - Reply Share
Where can I get a battery?
crzyinind - Reply Share
You can get one at Amazon, EBay and more.
Liu Woods - Share
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 65
All Time: 3,983
