Sprout Channel Cubby Camera Replacement
  1. Sprout Channel Cubby Camera Replacement, Dissasemble the device: step 1, image 1 of 2 Sprout Channel Cubby Camera Replacement, Dissasemble the device: step 1, image 2 of 2
    • Use an opening tool to push in and release sixteen small plastic clips around the edge of the case. As the clips are released, gradually pry the case apart.
    • It is easiest to start on the corners.
  2. Sprout Channel Cubby Camera Replacement, Remove the screw: step 2, image 1 of 1
    • Remove the single screw attaching the camera to the device.
  3. Sprout Channel Cubby Camera Replacement, Remove the camera: step 3, image 1 of 1
jasen biggins
741 Reputation
5 Guides authored
USF Tampa, Team 14-101, Meier Fall 2015 Member of USF Tampa, Team 14-101, Meier Fall 2015
USFT-MEIER-F15S14G101
4 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 18
All Time: 478
