Spy Gear Video Walkie Talkies Camera Replacement
  1. Spy Gear Video Walkie Talkies Camera Replacement, Top Cover: step 1, image 1 of 1
    • Remove the battery cover by removing the P1 Philips screw.
    • Remove the 3 AA batteries by hand.
  2. Spy Gear Video Walkie Talkies Camera Replacement: step 2, image 1 of 1
    • Unscrew Top Cover with a 3mm Triangle driver bit from the Driver Kit.
  3. Spy Gear Video Walkie Talkies Camera Replacement: step 3, image 1 of 1
    • Use Opening Tool to release barbed latch on top cover.
  4. Spy Gear Video Walkie Talkies Camera Replacement: step 4, image 1 of 1
    • Release pilot studs near the hinge with Metal Spudger.
  5. Spy Gear Video Walkie Talkies Camera Replacement: step 5, image 1 of 1
    • Once the Top Cover is free, you will have full access to the circuitry.
  6. Spy Gear Video Walkie Talkies Camera Replacement, Camera: step 6, image 1 of 1
    Tool used on this step:
    Buy
    • Use Tweezers to remove the side button.
  7. Spy Gear Video Walkie Talkies Camera Replacement: step 7, image 1 of 2 Spy Gear Video Walkie Talkies Camera Replacement: step 7, image 2 of 2
    • Release the zero insertion force (ZIF) connector.
    • Pull the ribbon cable away carefully.
  8. Spy Gear Video Walkie Talkies Camera Replacement: step 8, image 1 of 1
    • With the ribbon cable free from obstructions, use a Prying Tool to release the circuit board from the guide studs.
  9. Spy Gear Video Walkie Talkies Camera Replacement: step 9, image 1 of 1
    • With a plastic Prying Tool, separate the screen from the mounting tray.
    • Adhesive between the layers may provoke damage to the screen or tray. Take your time.
  10. Spy Gear Video Walkie Talkies Camera Replacement: step 10, image 1 of 1
    • Once the screen is completely folded away from the mounting tray, release it from the circuit board by hand.
  11. Spy Gear Video Walkie Talkies Camera Replacement: step 11, image 1 of 1
    • Release the back of the mounting tray using a plastic Pick to unhook the barb from the circuit board.
  12. Spy Gear Video Walkie Talkies Camera Replacement: step 12, image 1 of 1
    • Now remove the mounting tray complete with camera and ribbon cable attached by sliding away from the screen.
    • You must not damage the screen or screen ribbon cable in this step.
  13. Spy Gear Video Walkie Talkies Camera Replacement: step 13, image 1 of 1
    • Discard faulty camera and mounting tray.
2 other people completed this guide.
James French
151 Reputation
1 Guide authored
IUPUI, Team 7-7, Wilson Spring 2016 Member of IUPUI, Team 7-7, Wilson Spring 2016
IUPUI-WILSON-S16S7G7
5 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 8
All Time: 690
