Stanley ST-222A-120 Pressure Sensor Replacement
  1. Stanley ST-222A-120 Pressure Sensor Replacement, Pressure Sensor: step 1, image 1 of 1
    • Unplug the heater for safety during your repair.
  2. Stanley ST-222A-120 Pressure Sensor Replacement: step 2, image 1 of 3 Stanley ST-222A-120 Pressure Sensor Replacement: step 2, image 2 of 3 Stanley ST-222A-120 Pressure Sensor Replacement: step 2, image 3 of 3
    • With your hands gently remove the plastic covers on either side of the heater.
  3. Stanley ST-222A-120 Pressure Sensor Replacement: step 3, image 1 of 2 Stanley ST-222A-120 Pressure Sensor Replacement: step 3, image 2 of 2
    • Use your hands to pry apart the plastic halves of the heater to see the internals of the device.
  4. Stanley ST-222A-120 Pressure Sensor Replacement: step 4, image 1 of 2 Stanley ST-222A-120 Pressure Sensor Replacement: step 4, image 2 of 2
    • Locate small pressure sensor replacement and small pressure pin at the bottom of the device.
  5. Stanley ST-222A-120 Pressure Sensor Replacement: step 5, image 1 of 2 Stanley ST-222A-120 Pressure Sensor Replacement: step 5, image 2 of 2
    • Use your hands to help guide the pressure pin back into a position where the replacement plate can slide back onto it.
    • Needle nose pliers may be a good assistant in this situation.
  6. Stanley ST-222A-120 Pressure Sensor Replacement: step 6, image 1 of 2 Stanley ST-222A-120 Pressure Sensor Replacement: step 6, image 2 of 2
    • While the plastic is open hold the pin out with a finger.
    • Line up the pressure plate to the pressure pin.
  7. Stanley ST-222A-120 Pressure Sensor Replacement: step 7, image 1 of 2 Stanley ST-222A-120 Pressure Sensor Replacement: step 7, image 2 of 2
    • Gently put the pressure plate back onto the pressure pin.
  8. Stanley ST-222A-120 Pressure Sensor Replacement: step 8, image 1 of 3 Stanley ST-222A-120 Pressure Sensor Replacement: step 8, image 2 of 3 Stanley ST-222A-120 Pressure Sensor Replacement: step 8, image 3 of 3
    • Carefully press the plastic back together.
    • Be conscious not to interrupt the placement of the newly repaired pressure plate.
2 other people completed this guide.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 535
