Starbucks Barista Ready Light Replacement
  1. Starbucks Barista Ready Light Replacement, Ready Light: step 1, image 1 of 2 Starbucks Barista Ready Light Replacement, Ready Light: step 1, image 2 of 2
    • Unscrew the 6 screws from the back panel.
    • Remove the back panel.
  2. Starbucks Barista Ready Light Replacement: step 2, image 1 of 3 Starbucks Barista Ready Light Replacement: step 2, image 2 of 3 Starbucks Barista Ready Light Replacement: step 2, image 3 of 3
    • Locate the ready light.
    • Gently push the fixture against the Barista wall.
    • Pull the fixture straight up to release it.
    • Note: The fixture works as a spring.
    • Note: The green cover from the front panel will "pop" off. Do not lose the green cover.
    • Disconnect the wire lead connectors.
    • Remove the ready light unit (fixture).
  3. Starbucks Barista Ready Light Replacement: step 3, image 1 of 1
    • Replace the old LED with a new LED.
    • To put back, match the green cover to the slot of the LED fixture, then slide the fixture down against the barista wall.
David
748 Reputation
3 Guides authored
Cal Poly, Team 4-42, Regan Winter 2011 Member of Cal Poly, Team 4-42, Regan Winter 2011
CPSU-REGAN-W11S4G42
4 Members
5 Guides authored
4 Comments
Beee2smoove.
Rich Ridout - Reply
Youth and sports for
Rich Ridout - Reply
Ttuii addinsists
Rich Ridout - Reply
Where can I get a new LED bulb?
Paula - Reply
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 15
All Time: 6,142
