Steam Deck Battery Disconnection
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. Steam Deck Battery Disconnection, Prepare your Steam Deck for disassembly: step 1, image 1 of 3 Steam Deck Battery Disconnection, Prepare your Steam Deck for disassembly: step 1, image 2 of 3 Steam Deck Battery Disconnection, Prepare your Steam Deck for disassembly: step 1, image 3 of 3
    • Turn on your Steam Deck and allow the battery to discharge below 25% before starting your repairs, as a charged lithium-ion polymer battery can be dangerous if accidentally punctured.
    • As an extra precaution, Valve recommends putting your Steam Deck into battery storage mode within the BIOS before starting any internal repairs. Read how to do that here.
    • Power down your Steam Deck and unplug any cables.
    • If you have a microSD card installed, make sure to remove it before opening the Steam Deck. If you attempt to remove the back cover with it still installed, it could snap right in half.
    • During your repair, it can be helpful at times to lay the Steam Deck face-down into its case to protect the thumbsticks and prevent wobble.
  2. Steam Deck Battery Disconnection, Remove the back cover screws: step 2, image 1 of 1
    Tool used on this step:
    FixMat
    $36.95
    Buy
    • Use a Phillips driver to remove the eight screws securing the back cover:
    • Four coarse thread 9.5 mm-long screws
    • Four fine thread 5.8 mm-long screws
    • Despite the standards, Phillips screwdrivers can vary in size and shape—two drivers labeled as the same size may fit differently in the same screw. Use the size that fits the snuggest into the screw head.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your Steam Deck.
  3. Steam Deck Battery Disconnection, Unclip the back cover: step 3, image 1 of 2 Steam Deck Battery Disconnection, Unclip the back cover: step 3, image 2 of 2
    • Insert an opening pick into the thin gap between the back cover and the front shell, along the edge of the right grip.
    • If you're having trouble inserting your pick at the grip seam, try starting at either the top or bottom long edges first, then slide the pick towards the grip.
    • Pry up on the back cover to release it from the locking clips.
  4. Steam Deck Battery Disconnection, Remove the back cover: step 4, image 1 of 3 Steam Deck Battery Disconnection, Remove the back cover: step 4, image 2 of 3 Steam Deck Battery Disconnection, Remove the back cover: step 4, image 3 of 3
    • Once the clips are disconnected from one edge, the rest disconnect easily.
    • Grip the back cover at the opening you just created and pull it up and away from the device to unclip the long edges.
    • Remove the back cover.
  5. Steam Deck Battery Disconnection, Uncover the hidden shield screw: step 5, image 1 of 2 Steam Deck Battery Disconnection, Uncover the hidden shield screw: step 5, image 2 of 2
    Buy
    • If you have a refreshed Steam Deck version with the black motherboard cover, skip this step.
    • Use a pair of tweezers to remove the piece of foil tape covering the hidden screw on the board shield.
    • If possible, try not to rip or tear this tape so it can be reused. If necessary, you can fashion a replacement by cutting a piece of aluminum foil tape to fit.
  6. Steam Deck Battery Disconnection, Remove the shield screws: step 6, image 1 of 2 Steam Deck Battery Disconnection, Remove the shield screws: step 6, image 2 of 2
    • Use a Phillips driver to remove the three screws securing the board shield:
    • One 3.4 mm screw
    • Two 3.7 mm screws
    • Only the two 3.7 mm screws along the left edge are present in refreshed Steam Decks.
  7. Steam Deck Battery Disconnection, Remove the shield: step 7, image 1 of 3 Steam Deck Battery Disconnection, Remove the shield: step 7, image 2 of 3 Steam Deck Battery Disconnection, Remove the shield: step 7, image 3 of 3
    • Remove the board shield.
    • Depending on the age of your Steam Deck, this shield may stick to the thermal pads underneath.
    • During reassembly, ensure that the fan cable lays on the side of the board shield and isn't pinched underneath.
  8. Steam Deck Battery Disconnection, Disconnect the battery: step 8, image 1 of 3 Steam Deck Battery Disconnection, Disconnect the battery: step 8, image 2 of 3 Steam Deck Battery Disconnection, Disconnect the battery: step 8, image 3 of 3
    • Grip the battery cable by its pull tab and pull it directly away from the motherboard to disconnect it.
    • Alternatively, use the flat end of a spudger or a clean fingernail to gently push the connector out of its socket, then disconnect it completely by hand.
3 other people completed this guide.
Carsten Frauenheim
159,270 Reputation
439 Guides authored
iFixit Member of iFixit
Staff
124 Members
24,215 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 46
Past 30 Days: 188
All Time: 5,377
