Steam Deck OLED Back Cover Replacement
  1. Steam Deck OLED Back Cover Replacement, Prepare your Steam Deck for disassembly: step 1, image 1 of 3 Steam Deck OLED Back Cover Replacement, Prepare your Steam Deck for disassembly: step 1, image 2 of 3 Steam Deck OLED Back Cover Replacement, Prepare your Steam Deck for disassembly: step 1, image 3 of 3
    • Turn on your Steam Deck and allow the battery to discharge below 25% before starting your repairs, as a charged lithium-ion polymer battery can be dangerous if accidentally punctured.
    • As an extra precaution, Valve recommends putting your Steam Deck into battery storage mode within the BIOS before starting any internal repairs. Read how to do that here.
    • Power down your Steam Deck and unplug any cables.
    • If you have a microSD card installed, make sure to remove it before opening the Steam Deck. If you attempt to remove the back cover with it still installed, it could snap right in half.
    • During your repair, it can be helpful at times to lay the Steam Deck face-down in its case to protect the thumbsticks and prevent wobble.
  2. Steam Deck OLED Back Cover Replacement, Remove the back cover screws: step 2, image 1 of 2 Steam Deck OLED Back Cover Replacement, Remove the back cover screws: step 2, image 2 of 2
    Tool used on this step:
    FixMat
    $36.95
    Buy
    • Use a T6 Torx driver to remove the eight 5.8 mm‑long screws securing the back cover.
  3. Steam Deck OLED Back Cover Replacement, Unclip a handle: step 3, image 1 of 3 Steam Deck OLED Back Cover Replacement, Unclip a handle: step 3, image 2 of 3 Steam Deck OLED Back Cover Replacement, Unclip a handle: step 3, image 3 of 3
    • Insert an opening pick at an upward angle between the back cover and the front shell near one of the triggers.
    • If you can't insert your pick here, try along the top or bottom edges of the Steam Deck OLED before sliding it toward the handle.
    • Slide your pick along the edge of the handle to release the clips securing it to the front shell.
  4. Steam Deck OLED Back Cover Replacement, Unclip the top and bottom edges: step 4, image 1 of 3 Steam Deck OLED Back Cover Replacement, Unclip the top and bottom edges: step 4, image 2 of 3 Steam Deck OLED Back Cover Replacement, Unclip the top and bottom edges: step 4, image 3 of 3
    • Reinsert your pick and slide it along the top and bottom edges until the back cover feels loose.
  5. Steam Deck OLED Back Cover Replacement, Remove the back cover: step 5, image 1 of 3 Steam Deck OLED Back Cover Replacement, Remove the back cover: step 5, image 2 of 3 Steam Deck OLED Back Cover Replacement, Remove the back cover: step 5, image 3 of 3
    • Grip the unclipped handle and pull it away from the front shell to release the remaining clips.
    • Remove the back cover.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Steam Deck OLED answers community for help.
2 other people completed this guide.
Clay Eickemeyer
81,913 Reputation
455 Guides authored
Guide Team Member of Guide Team
Staff
9 Members
11,426 Guides authored
One Comment
he doesn't tell you how to install. might seem like it's overheating after opening the back plate and I was looking for instructions to see if maybe I missed something when reinstalling the stock back plate
John Doe - Reply
Past 24 Hours: 18
Past 7 Days: 72
Past 30 Days: 412
All Time: 6,737
