Steam Deck OLED Battery Reconnection (Alternate)
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Steam Deck OLED Battery Reconnection (Alternate), Reassembly instructions: step 1, image 1 of 2 Steam Deck OLED Battery Reconnection (Alternate), Reassembly instructions: step 1, image 2 of 2
    • During disassembly, skip the next four steps.
    • During reassembly:
    • Reinstall the two 3.8 mm‑long screws to secure the motherboard shield.
    • Reconnect the interconnect cable ZIF connector.
  2. Steam Deck OLED Battery Reconnection (Alternate), Reassembly instructions: step 2, image 1 of 3 Steam Deck OLED Battery Reconnection (Alternate), Reassembly instructions: step 2, image 2 of 3 Steam Deck OLED Battery Reconnection (Alternate), Reassembly instructions: step 2, image 3 of 3
    • Use the flat end of a spudger to slide the battery connector into its socket on the motherboard.
  3. Steam Deck OLED Battery Reconnection (Alternate), Reassembly instructions: step 3, image 1 of 3 Steam Deck OLED Battery Reconnection (Alternate), Reassembly instructions: step 3, image 2 of 3 Steam Deck OLED Battery Reconnection (Alternate), Reassembly instructions: step 3, image 3 of 3
    • Use your T6 Torx driver to remove the two 3.8 mm‑long screws securing the motherboard shield.
    • Lift the top edge of the motherboard shield up and flip it over the bottom edge of the frame, away from the motherboard.
    • Be careful not to crease or strain the cable.
  4. Steam Deck OLED Battery Reconnection (Alternate), Reassembly instructions: step 4, image 1 of 3 Steam Deck OLED Battery Reconnection (Alternate), Reassembly instructions: step 4, image 2 of 3 Steam Deck OLED Battery Reconnection (Alternate), Reassembly instructions: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • During reassembly, follow this step and the above four steps to reconnect the battery.
    • In this reassembly step, you'll disconnect the interconnect cable to free the motherboard shield.
    • Use a spudger to flip up the small white locking flap on the right button board interconnect cable ZIF connector.
    • Use tweezers or your fingers to grip the cable's pull tab and slide it straight out of its socket to disconnect it.
    • The pull tab may be labelled C‑R.
Clay Eickemeyer
81,040 Reputation
455 Guides authored
Guide Team Member of Guide Team
Staff
9 Members
11,341 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 13
All Time: 27
