Introduction
Prerequisite-only guide! This guide is part of another procedure and is not meant to be used alone.
Use this guide to remove the SSD in your Steam Deck.
Power down your Steam Deck and unplug any cables.
Use a Phillips driver to remove the eight screws securing the back cover:
Four coarse thread 9.5 mm-long screws
Four fine thread 5.8 mm-long screws
Insert an opening pick into the thin gap between the back cover and the front shell, along the edge of the right grip.
Pry up on the back cover to release it from the locking clips.
Grip the back cover at the opening you just created and pull it up and away from the device to unclip the long edges.
Remove the back cover.
Use a pair of tweezers to remove the piece of foil tape covering the hidden screw on the board shield.
Use a Phillips driver to remove the three screws securing the board shield:
One 3.4 mm screw
Two 3.7 mm screws
Grip the battery cable by its pull tab and pull it directly away from the motherboard to disconnect it.
Grip the end of the SSD and pull it away from its M.2 board connector to remove it.
