Acer Chromebook C720-2844 Heatsink and Cooling Fan Replacement
  1. Acer Chromebook C720-2844 Heatsink and Cooling Fan Replacement, Heatsink and Cooling Fan: step 1, image 1 of 1
    • Unscrew and remove the four 1 cm Phillips #00 screws from the heatsink.
  2. Acer Chromebook C720-2844 Heatsink and Cooling Fan Replacement: step 2, image 1 of 1
    • Proceed to unscrew and remove the two 1 cm Phillips #00 screws holding the fan in place.
  3. Acer Chromebook C720-2844 Heatsink and Cooling Fan Replacement: step 3, image 1 of 3 Acer Chromebook C720-2844 Heatsink and Cooling Fan Replacement: step 3, image 2 of 3 Acer Chromebook C720-2844 Heatsink and Cooling Fan Replacement: step 3, image 3 of 3
    • Remove the fan connection from the motherboard.
    • Disconnect the black & white cables.
    • Remove the cables from the hooks on the fan housing.
  4. Acer Chromebook C720-2844 Heatsink and Cooling Fan Replacement: step 4, image 1 of 1
    • Lift up to remove the cooling fan and heatsink.
Christian Madrigal
229 Reputation
2 Guides authored
Gateway, Team 1-2, Pee Spring 2022 Member of Gateway, Team 1-2, Pee Spring 2022
GCC-PEE-S22S1G2
4 Members
4 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 224
