Steam iron - Step 1: The different functions
  1. Steam iron - Step 1: The different functions, What are the functions of an iron?: step 1, image 1 of 1
    • The name iron comes from the actual metal that the appliance is made from. The shape of the iron, pointed at its end, allows you to iron all the corners of the clothes, while its weight smoothes the fabric.
    • The part of the iron that makes direct contact with the fabric is called the "sole (plate)". In order for the iron to be effective, then the device needs to be heated. This iron also makes use of a steam system, which makes it possible to humidify the fabric during the ironing process.
    • Ironing helps loosen the bonds between the long chains of molecules that make up polymer fiber materials. The heat and weight of the iron stretches the fibers while the fabric retains its new shape once it's cooled. Some materials, like cotton, require the use of water to loosen intermolecular bonds.
    • Information about steam irons
    • Information (2) on steam irons
    • Wikipedia link - Clothes iron
  2. Steam iron - Step 1: The different functions, Device description: step 2, image 1 of 2 Steam iron - Step 1: The different functions, Device description: step 2, image 2 of 2
    • The iron rests on a reservoir with a temperature-resistant base.
    • At the front of the water tank, a removable spout serves as a funnel to allow a user to fill the reservoir with water (1.7l)
    • Theirs a button on the top of the device, which locks the iron to the reservoir base.
    • At the rear is a control panel made up of three buttons.
  3. Steam iron - Step 1: The different functions, Device controls: step 3, image 1 of 3 Steam iron - Step 1: The different functions, Device controls: step 3, image 2 of 3 Steam iron - Step 1: The different functions, Device controls: step 3, image 3 of 3
    • The control panel consists of three buttons. the Central button = On/Off, the Left button = Eco Mode, and the Right button = Anti-limescale function
    • Central button: allows the iron to operate with a short press. When the button is pressed a steady blue light comes on. After approximately 2 minutes, the appliance beeps to signal that the peak temperature has been reached and that the iron is ready to be used.
    • A long press on this button while ironing switches to "Turbo" mode. The iron will emit more steam, and the blue light turns white.
    • Left button: pressing this button during ironing will decrease the volume of steam along with the temperature of the iron.
    • Right button: This function helps prevent limescale deposits. By pressing this button the iron will produce steam continuously for 2 minutes in Turbo mode.
    • The button for sending steam is located on the handle of the iron. This button is fitted with a light which flashes until the temperature is reached on start-up.
We now know what an XL reservoir steam iron is and what these different features are. We can move on to studying how it works in the following tutorial: "How does it work?"
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Atelier Soudé
3,355 Reputation
15 Guides authored
Atelier Soudé Member of Atelier Soudé
Local Repair Groups
5 Members
28 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 18
Past 30 Days: 124
All Time: 4,579
