SteelSeries Apex 64145 USB Port Connector Replacement
  1. SteelSeries Apex 64145 USB Port Connector Replacement, Gel Membrane: step 1, image 1 of 1
    • Unplug the keyboard from the computer.
  2. SteelSeries Apex 64145 USB Port Connector Replacement: step 2, image 1 of 1
    • Unscrew the twenty black 4.5 mm Phillips #1 screws on the back of the keyboard.
  3. SteelSeries Apex 64145 USB Port Connector Replacement: step 3, image 1 of 1
    • Pry open the back of the keyboard.
  4. SteelSeries Apex 64145 USB Port Connector Replacement: step 4, image 1 of 2 SteelSeries Apex 64145 USB Port Connector Replacement: step 4, image 2 of 2
    • Remove the gel membrane.
  5. SteelSeries Apex 64145 USB Port Connector Replacement, LED: step 5, image 1 of 2 SteelSeries Apex 64145 USB Port Connector Replacement, LED: step 5, image 2 of 2
    • Unscrew the two silver 4.0 mm Phillips #1 screws and the three black 6.5 mm Phillips #1 screws holding the silicone sheets.
  6. SteelSeries Apex 64145 USB Port Connector Replacement: step 6, image 1 of 1
    • Flip the chip slightly in order to remove the sheets.
  7. SteelSeries Apex 64145 USB Port Connector Replacement: step 7, image 1 of 1
    • Remove the sheets.
  8. SteelSeries Apex 64145 USB Port Connector Replacement: step 8, image 1 of 2 SteelSeries Apex 64145 USB Port Connector Replacement: step 8, image 2 of 2
    • Unscrew the two silver 4.5 mm Phillips #1 screws and the seven 5.0 mm Phillips #1 screws that deter the plastic panel from removal.
  9. SteelSeries Apex 64145 USB Port Connector Replacement: step 9, image 1 of 1
    • Remove the plastic panel and the white sheet.
  10. SteelSeries Apex 64145 USB Port Connector Replacement: step 10, image 1 of 3 SteelSeries Apex 64145 USB Port Connector Replacement: step 10, image 2 of 3 SteelSeries Apex 64145 USB Port Connector Replacement: step 10, image 3 of 3
    • Unplug the wires connected to the LEDs.
  11. SteelSeries Apex 64145 USB Port Connector Replacement: step 11, image 1 of 2 SteelSeries Apex 64145 USB Port Connector Replacement: step 11, image 2 of 2
    • Remove the LEDs.
  12. SteelSeries Apex 64145 USB Port Connector Replacement, USB Port Connector: step 12, image 1 of 1
    • Unscrew the two 4.5 mm silver Phillips #1 screws that hold the USB port connector.
  13. SteelSeries Apex 64145 USB Port Connector Replacement: step 13, image 1 of 1
    • Unplug the wires and remove the USB port connector.
2 other people completed this guide.
Zwe Phone Shein
559 Reputation
5 Guides authored
USF Tampa, Team S1-G1, Nance Spring 2017 Member of USF Tampa, Team S1-G1, Nance Spring 2017
USFT-NANCE-S17S1G1
4 Members
10 Guides authored
2 Comments
the 2 usb in the keyboard what amp are they running on.. 500mA ? I hope for 1500-2000 mA
And what standard are they ? USB3 ??
Simon Sundström - Reply
can the other part be replaced too. like the power board ?
i think i have a powerboard problem and if I can replace it that would be awesome, as I love my keyboard and im
very very attached to it. I was playing a video game, nothing too harsh , and the lights went out and poof it never came back. never had a problem with this keyboard until 2 and a 1/2 years later that it did this. Its in a non-smoking room and gaming studio always kept very clean.
I would love to fix it to bring it back to life.
Twsted - Reply
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 46
All Time: 3,140
