SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement
  1. SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement, GameDAC Potentiometer: step 1, image 1 of 3 SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement, GameDAC Potentiometer: step 1, image 2 of 3 SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement, GameDAC Potentiometer: step 1, image 3 of 3
    • Remove the plastic cover using the iFixit opening tool to pry the cover open.
    • Insert opening picks to keep the cover open as you work your way around the GameDAC.
    • Pop the cover off.
  2. SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement: step 2, image 1 of 2 SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement: step 2, image 2 of 2
    • Remove the control wheel from the GameDAC by pulling on the knob.
  3. SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement: step 3, image 1 of 2 SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement: step 3, image 2 of 2
    • Remove the five 6mm screws using the Phillips #0 driver head.
    • There is one screw hidden on the upper right-hand side of the display.
  4. SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement: step 4, image 1 of 2 SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement: step 4, image 2 of 2
    • Hold the sides of the GameDAC and pull apart.
    • Don't pull the two sides apart quickly or forcefully to avoid tearing the wire connection between the two boards.
  5. SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement: step 5, image 1 of 1
    • Remove the three 4mm screws from the circuit board using the Phillips #0 driver head.
  6. SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement: step 6, image 1 of 2 SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement: step 6, image 2 of 2
    • Desolder the seven potentiometer pins from the board to remove the button.
    • For help desoldering connections, follow this useful guide on How To Solder and Desolder Connections.
    • Use caution when soldering. The heated tip may cause damage to the board or burn you.
5 other people completed this guide.
Avinash Vadlamudi
451 Reputation
1 Guide authored
Cal Poly, Team S18-G1, White Winter 2019 Member of Cal Poly, Team S18-G1, White Winter 2019
CPSU-WHITE-W19S18G1
4 Members
21 Guides authored
3 Comments
Hi there,
do you know what type of potentiometer is needed?
Greetings
Chris
Christian Humann - Reply
I would like to know too. Cause it failed for me as well!!
Antonis Lazarakis - Reply
Can I replace the Oled Screen with 2,42 inch arduino oled display that also have 24pin flex?
Muso!27 - Reply
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 79
All Time: 4,615
