Step Guide To Install KDZ Firmware Using LG Flash Tool
    • Download the LG flash tool from lgflash.com and extract it on your Windows PC and launch the application
    • Boot your mobile device into download mode by power of the device and holding the Volume Up button.
    • Connet it to the pc using a proper USB cable.
    • Then it is the time for you to load the kdz firmware file into LG Flash Tool window on your PC. Click on the browse button at the end of the 'Select KDZ file' line.
    • Once you selected the KDZ file Click on CSE Flash button to start the flashing process Remember: The application consists of two different flashing options as CSE and Normal. CSE method wipes away the all the date available on your device But the normal method does not. If you want to upgrade from a stock firmware, selest normal
    • Hit on the start button to proceed. it may be asked for administrator permissions for some LG program on your PC, if just accept it. Select the appropriate language.
    • Keep in mind not to tick the Smartphone upgrade checkbox, it’s for Windows Mobile phones, not your LG device running on Android. Finally, You can start the flashing process. Wait Until it does 100%.
15 other people completed this guide.
Ana Schumacher
744 Reputation
1 Guide authored
1 Guide Comment
Got a step by step to downgrade to 10 from 13 on the LG v60 thinq 5g? Phone is from ATT
Keith Kilpatrick - Reply
Past 24 Hours: 8
Past 7 Days: 74
Past 30 Days: 318
All Time: 28,526
