Sterwins 460BSP500E-3 Mower Air Filter Replacement
  1. Sterwins 460BSP500E-3 Mower Air Filter Replacement, Locate the air filter cover: step 1, image 1 of 1
    • The air filter is located inside a plastic housing mounted on the left side of the engine.
  2. Sterwins 460BSP500E-3 Mower Air Filter Replacement, Open the air filter cover: step 2, image 1 of 3 Sterwins 460BSP500E-3 Mower Air Filter Replacement, Open the air filter cover: step 2, image 2 of 3 Sterwins 460BSP500E-3 Mower Air Filter Replacement, Open the air filter cover: step 2, image 3 of 3
    • Lift up the cover locking tab located on the top of the filter housing.
    • Swing the cover open.
    • Once it is fully open, lift the cover off the hinges and remove it.
  3. Sterwins 460BSP500E-3 Mower Air Filter Replacement, Remove the air filter: step 3, image 1 of 1
    • Grasp the old filter and pull it out of the housing.
  4. Sterwins 460BSP500E-3 Mower Air Filter Replacement, Clean the filter housing: step 4, image 1 of 1
    • Remove old oil and dirt from the inside of the filter housing with absorbent paper or cloth.
  5. Sterwins 460BSP500E-3 Mower Air Filter Replacement, Filter replacement: step 5, image 1 of 1
    • Soak the new air filter with a teaspoon of motor oil.
    • Position the air filter in the housing.
  6. Sterwins 460BSP500E-3 Mower Air Filter Replacement, Reinstall the cover: step 6, image 1 of 2 Sterwins 460BSP500E-3 Mower Air Filter Replacement, Reinstall the cover: step 6, image 2 of 2
    • Replace the cover by aligning the two lower hinge tabs in their slots.
  7. Sterwins 460BSP500E-3 Mower Air Filter Replacement, Latching the cover: step 7, image 1 of 1
    • Swing the cover back up into place. Press firmly on the top edge until the latch seats.
Finish Line
Special thanks to these translators:
fr en
100%
Jerry Wheeler is helping us fix the world! Want to contribute?
Start translating ›
iRobot
1 Reputation
636 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 17
All Time: 236
