Summer 3D Lite Convenience Stroller Back Wheel Replacement
  1. Summer 3D Lite Convenience Stroller Back Wheel Replacement, Back Wheel: step 1, image 1 of 2 Summer 3D Lite Convenience Stroller Back Wheel Replacement, Back Wheel: step 1, image 2 of 2
    • Set the stroller up so the front wheel is on the ground with the metal push tab up.
  2. Summer 3D Lite Convenience Stroller Back Wheel Replacement: step 2, image 1 of 2 Summer 3D Lite Convenience Stroller Back Wheel Replacement: step 2, image 2 of 2
    • Push the tab in with your finger enough so the plastic can slip out above the tab.
  3. Summer 3D Lite Convenience Stroller Back Wheel Replacement: step 3, image 1 of 1
    • OPTIONAL: If the tab is being difficult, use a key to push the tab in further in order to slip plastic out of place.
  4. Summer 3D Lite Convenience Stroller Back Wheel Replacement: step 4, image 1 of 1
    • The wheel should slide right off the pole once the tab is pushed out of place. It is now possible to make repairs or replace the wheel completely.
4 other people completed this guide.
Nick Taylor
188 Reputation
1 Guide authored
Cal Poly, Team 11-5, Forte Fall 2015 Member of Cal Poly, Team 11-5, Forte Fall 2015
CPSU-FORTE-F15S11G5
4 Members
3 Guides authored
2 Comments
Gd, have a question . Were can u buy spare parts for this type of stroller?
pieterroos - Reply
Can you tell me if you have a rear wheel that will fit a summer 3D go convenience stroller all black?
charles nelms - Reply
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 108
All Time: 11,082
