SuperTooth Buddy Battery replacement
  1. SuperTooth Buddy Battery replacement, Rechargeable batteries: step 1, image 1 of 1
    • Carefully lift off the glued on cover.
  2. SuperTooth Buddy Battery replacement: step 2, image 1 of 1
    • Remove the two screws on the right.
    • There is also a small screw to the left of the green button
  3. SuperTooth Buddy Battery replacement: step 3, image 1 of 1
    • There are also two screws on the back that need to be removed
  4. SuperTooth Buddy Battery replacement: step 4, image 1 of 1
    • Be careful when lifting off the cover so as not to damage the two thin speaker cables.
    • Carefully remove the two screws holding the circuit board in place.
    • The battery is located under the circuit board
  5. SuperTooth Buddy Battery replacement: step 5, image 1 of 1
    • Order a replacement battery online.
    • Li-ION 3.7V 650mAh 2.41 Wh
    • Make sure that the new battery has the same dimensions as the old one. (In this case it was approx. 50mm x 30mm x 4mm.
3 other people completed this guide.
Special thanks to these translators:
de en
100%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
markus1980wien
143 Reputation
1 Guide authored
2 Guide Comments
Ottime istruzioni per lo smontaggio. Grazie. Fino ad ora non ho trovato la batteria sostitutiva su internet. Spero di trovarla.
Eva Verlicchi - Reply Share
Si può sostituire con una simile, che si trova su Ebay o su Aliexpress, il modello e: ***Batteria a litio 600mAh 3.7 V ricaricabile misura 503040 per dispositivi elettronici. Il Link: https://www.ebay.it/itm/175641031768 oppure: https://it.aliexpress.com/item/322148476...
Claus Col - Reply Share
Past 24 Hours: 10
Past 7 Days: 22
Past 30 Days: 62
All Time: 4,735
