Supersonic SC-777BT Camera Replacement
  1. Supersonic SC-777BT Camera Replacement, Camera: step 1, image 1 of 3 Supersonic SC-777BT Camera Replacement, Camera: step 1, image 2 of 3 Supersonic SC-777BT Camera Replacement, Camera: step 1, image 3 of 3
    • Remove the back cover using the plastic opening tool.
    • Open the cover like a book so you do not disconnect the yellow plastic holding the cover to the motherboard.
  2. Supersonic SC-777BT Camera Replacement: step 2, image 1 of 3 Supersonic SC-777BT Camera Replacement: step 2, image 2 of 3 Supersonic SC-777BT Camera Replacement: step 2, image 3 of 3
    Tool used on this step:
    Buy
    • Remove the two screws using the screwdriver.
    • Use the tweezers to pull the camera out of place.
    • Be gentle while pulling it out so you do not pull any extra components out.
  3. Supersonic SC-777BT Camera Replacement: step 3, image 1 of 1
    • Disconnect the yellow ribbon cable from the connector.
  4. Supersonic SC-777BT Camera Replacement: step 4, image 1 of 2 Supersonic SC-777BT Camera Replacement: step 4, image 2 of 2
    • Remove camera.
    • It should just peel off like a sticker.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 147
