Surface Laptop Studio Fan Replacement
  1. Surface Laptop Studio Fan Replacement, Lower Case: step 1, image 1 of 1
    Tool used on this step:
    Buy
    • Remove the rubber cosmetic strip along the outside edge of the back plate with tweezers.
  2. Surface Laptop Studio Fan Replacement: step 2, image 1 of 2 Surface Laptop Studio Fan Replacement: step 2, image 2 of 2
    • Remove the two rubber feet on the lower case with an opening tool.
  3. Surface Laptop Studio Fan Replacement: step 3, image 1 of 1
    • Remove the two screws with a T3 Torx screwdriver.
  4. Surface Laptop Studio Fan Replacement: step 4, image 1 of 1
    • Remove the seven screws securing the lower case with a T3 Torx screwdriver.
  5. Surface Laptop Studio Fan Replacement: step 5, image 1 of 2 Surface Laptop Studio Fan Replacement: step 5, image 2 of 2
    • Lift the lower case gently and set it above the device.
    • Take care not to strain the battery cable as you move the lower case.
  6. Surface Laptop Studio Fan Replacement, Surface Laptop Studio Battery Disconnection: step 6, image 1 of 2 Surface Laptop Studio Fan Replacement, Surface Laptop Studio Battery Disconnection: step 6, image 2 of 2
    • Disconnect the battery cable by lifting the pull tab until it "clicks."
  7. Surface Laptop Studio Fan Replacement, Fan: step 7, image 1 of 2 Surface Laptop Studio Fan Replacement, Fan: step 7, image 2 of 2
    • Remove the screws securing both of the fans with a T3 Torx screwdriver.
  8. Surface Laptop Studio Fan Replacement: step 8, image 1 of 1
    • Flip up the ZIF locking flap on each socket.
    • Disconnect the ribbon cables attached to each fan.
  9. Surface Laptop Studio Fan Replacement: step 9, image 1 of 2 Surface Laptop Studio Fan Replacement: step 9, image 2 of 2
    • Lift the fans up and out.
6 Guide Comments
Any idea where to buy the parts?
cameronjpu - Reply Share
Any luck in getting the fan replacement part?
Carlos Pino Tinetti - Share
Same question, where I can buy those cover plastic stuff.
Mingyuan Ma - Reply Share
I am also looking for the fan parts
Mike Van Laningham - Reply Share
Hi, i am looking also for fan parts. If anybody knows, that would be awesome!
Matthias Bockbreder - Reply Share
Past 24 Hours: 13
Past 7 Days: 83
Past 30 Days: 267
All Time: 6,588
