Surface Laptop Studio Headphone Jack Replacement
  1. Surface Laptop Studio Headphone Jack Replacement, Lower Case: step 1, image 1 of 1
    Tool used on this step:
    Buy
    • Remove the rubber cosmetic strip along the outside edge of the back plate with tweezers.
  2. Surface Laptop Studio Headphone Jack Replacement: step 2, image 1 of 2 Surface Laptop Studio Headphone Jack Replacement: step 2, image 2 of 2
    • Remove the two rubber feet on the lower case with an opening tool.
  3. Surface Laptop Studio Headphone Jack Replacement: step 3, image 1 of 1
    • Remove the two screws with a T3 Torx screwdriver.
  4. Surface Laptop Studio Headphone Jack Replacement: step 4, image 1 of 1
    • Remove the seven screws securing the lower case with a T3 Torx screwdriver.
  5. Surface Laptop Studio Headphone Jack Replacement: step 5, image 1 of 2 Surface Laptop Studio Headphone Jack Replacement: step 5, image 2 of 2
    • Lift the lower case gently and set it above the device.
    • Take care not to strain the battery cable as you move the lower case.
  6. Surface Laptop Studio Headphone Jack Replacement, Surface Laptop Studio Battery Disconnection: step 6, image 1 of 2 Surface Laptop Studio Headphone Jack Replacement, Surface Laptop Studio Battery Disconnection: step 6, image 2 of 2
    • Disconnect the battery cable by lifting the pull tab until it "clicks."
  7. Surface Laptop Studio Headphone Jack Replacement, Headphone Jack: step 7, image 1 of 3 Surface Laptop Studio Headphone Jack Replacement, Headphone Jack: step 7, image 2 of 3 Surface Laptop Studio Headphone Jack Replacement, Headphone Jack: step 7, image 3 of 3
    • Remove the left I/O bracket by unscrewing the the 3 M1109237 Screws with your T3 Torx screwdriver.
  8. Surface Laptop Studio Headphone Jack Replacement: step 8, image 1 of 1
    • Remove the two M1168360 screws on the headphone jack with your T3 Torx screwdriver.
  9. Surface Laptop Studio Headphone Jack Replacement: step 9, image 1 of 1
    • Flip up the headphone jack's ZIF connector locking flap.
    • Remove the ribbon cable from the port.
  10. Surface Laptop Studio Headphone Jack Replacement: step 10, image 1 of 1
    Buy
    • Lift the headphone jack up and out with your tweezers.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 226
