Surfboard Futures Fin Replacement
  1. Surfboard Futures Fin Replacement, Futures Fin: step 1, image 1 of 3 Surfboard Futures Fin Replacement, Futures Fin: step 1, image 2 of 3 Surfboard Futures Fin Replacement, Futures Fin: step 1, image 3 of 3
    • Lay your surfboard down on a flat, durable surface long enough to support the length of your board.
  2. Surfboard Futures Fin Replacement: step 2, image 1 of 3 Surfboard Futures Fin Replacement: step 2, image 2 of 3 Surfboard Futures Fin Replacement: step 2, image 3 of 3
    • Make sure the small screw hole in front of the fin is free of debris and sand.
    • Insert the key into the hole and begin turning counter-clockwise to loosen the screw inside.
  3. Surfboard Futures Fin Replacement: step 3, image 1 of 2 Surfboard Futures Fin Replacement: step 3, image 2 of 2
    • Continue turning counter-clockwise until the screw is free.
  4. Surfboard Futures Fin Replacement: step 4, image 1 of 3 Surfboard Futures Fin Replacement: step 4, image 2 of 3 Surfboard Futures Fin Replacement: step 4, image 3 of 3
    • Firmly grasp the fin with one hand and place your other hand on the surfboard for stabilization.
    • Simultaneously lift the fin while tilting it backwards to remove the fin.
  5. Surfboard Futures Fin Replacement: step 5, image 1 of 2 Surfboard Futures Fin Replacement: step 5, image 2 of 2
    • Notice the circular inlet on the rear bottom side of the fin. This inlet of the fin fits snuggly into the little rod located in the back of the fin slit on the board, much like a puzzle.
  6. Surfboard Futures Fin Replacement: step 6, image 1 of 3 Surfboard Futures Fin Replacement: step 6, image 2 of 3 Surfboard Futures Fin Replacement: step 6, image 3 of 3
    • With your new or repaired fin, insert the back in first so that you feel the inlet on the fin clip into the little rod in the slit.
    • Once you feel the back secure, bring the front of the fin down into the slit.
  7. Surfboard Futures Fin Replacement: step 7, image 1 of 3 Surfboard Futures Fin Replacement: step 7, image 2 of 3 Surfboard Futures Fin Replacement: step 7, image 3 of 3
    • Place the screw back into the hole and begin turning clockwise using the key.
    • Continue turning until the screw is tight and won't turn any more.
    • Once the screw stops turning, do not continue to tighten or you may damage the screw or fin.
  8. Surfboard Futures Fin Replacement: step 8, image 1 of 1
    • Make sure the screw can no longer be seen.
    • Wiggle your fin gently to test for looseness, and you have successfully replaced your surfboard fin.
Finish Line
2 other people completed this guide.
Hudson Albert
165 Reputation
1 Guide authored
Cal Poly, Team 10-3, Green Fall 2015 Member of Cal Poly, Team 10-3, Green Fall 2015
CPSU-GREEN-F15S10G3
4 Members
4 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 20
All Time: 4,673
