Surfboard Traction Pad Replacement
  1. Surfboard Traction Pad Replacement, Traction Pad: step 1, image 1 of 2 Surfboard Traction Pad Replacement, Traction Pad: step 1, image 2 of 2
    • Apply protective gloves.
  2. Surfboard Traction Pad Replacement: step 2, image 1 of 3 Surfboard Traction Pad Replacement: step 2, image 2 of 3 Surfboard Traction Pad Replacement: step 2, image 3 of 3
    • Pull up the traction pad from the surfboard.
    • This allows for an easy start to cutting the adhesive.
  3. Surfboard Traction Pad Replacement: step 3, image 1 of 2 Surfboard Traction Pad Replacement: step 3, image 2 of 2
    • Using a razor blade, cut away at the adhesive under the traction pad.
  4. Surfboard Traction Pad Replacement: step 4, image 1 of 2 Surfboard Traction Pad Replacement: step 4, image 2 of 2
    • Completely remove each section of the traction pad leaving only excess adhesive.
  5. Surfboard Traction Pad Replacement: step 5, image 1 of 3 Surfboard Traction Pad Replacement: step 5, image 2 of 3 Surfboard Traction Pad Replacement: step 5, image 3 of 3
    • Apply adhesive remover to the paper towels.
    • Apply the paper towels to the section of the board with excess adhesive until it is covered.
    • Let it stand for 5 minutes.
  6. Surfboard Traction Pad Replacement: step 6, image 1 of 3 Surfboard Traction Pad Replacement: step 6, image 2 of 3 Surfboard Traction Pad Replacement: step 6, image 3 of 3
    • Remove the paper towels from the board.
    • Cut away the rest of the excess adhesive.
    • Dry the board with paper towels.
Now the tail of your board is clean and ready for a new traction pad.
Sean Hinkson
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 14
All Time: 573
