SwagTron T1 Battery Replacement
  1. SwagTron T1 Battery Replacement, Back Panels: step 1, image 1 of 1
    • Ensure that the SwagTron is off.
    • Turn the SwagTron upside down to see the underside.
  2. SwagTron T1 Battery Replacement: step 2, image 1 of 3 SwagTron T1 Battery Replacement: step 2, image 2 of 3 SwagTron T1 Battery Replacement: step 2, image 3 of 3
    • Unscrew the eighteen 10mm screws that secure the back panels using a Phillips #2 screwdriver.
    • The screws are tightly in place. It will take effort to screw them out.
    • The panel is still attached to the SwagTron by wires that go to the motherboard.
    • Carefully lift the panels off
  3. SwagTron T1 Battery Replacement: step 3, image 1 of 3 SwagTron T1 Battery Replacement: step 3, image 2 of 3 SwagTron T1 Battery Replacement: step 3, image 3 of 3
    • Follow the wires from the panels to the motherboard.
    • You may need to cut any zip ties that are holding the wires together.
    • There is one connection on the battery side and three on the other side that must be removed.
    • These connections may be difficult to remove. Try to securely press the connection and pull firmly.
    • Your back panels are now completely removed.
  4. SwagTron T1 Battery Replacement, Battery: step 4, image 1 of 1
    • Your SwagTron should look like this once the back panels are removed.
    • The battery is located on the left side as shown.
  5. SwagTron T1 Battery Replacement: step 5, image 1 of 2 SwagTron T1 Battery Replacement: step 5, image 2 of 2
    • Unscrew the four 10mm screws that secure the battery using a Philips #2 screwdriver.
    • The screws may be tightly in place. If so, use some effort to unscrew them.
    • The battery is still connected to two wires that go to the motherboard.
  6. SwagTron T1 Battery Replacement: step 6, image 1 of 3 SwagTron T1 Battery Replacement: step 6, image 2 of 3 SwagTron T1 Battery Replacement: step 6, image 3 of 3
    • Disconnect the two wires that come from the battery from the wires coming from the hoverboard.
    • There are only two connections that need to be separated.
    • The battery should be completely removed from the hoverboard.
7 other people completed this guide.
Adrian Abarca
363 Reputation
2 Guides authored
Cal Poly, Team S17-G5, Banghart Spring 2017 Member of Cal Poly, Team S17-G5, Banghart Spring 2017
CPSU-BANGHART-S17S17G5
4 Members
5 Guides authored
13 Comments
Is there a blue and black wire that gets connected also?
Where dI you get the battery.
Thanks.
Paul Bromberg - Reply
I’m also wanting to know where you found the replacement battery. I’ve found several replacement battery packs for hover boards but none that match the T1. The T1 has a circuit board attached to the battery pack, fused…. where can I find this?
Daniel O'Brien - Reply
Yep, can’t find a T1 battery anywhere. Even Swagtron won’t tell me how to get one, short of sending it in for service.
renystro - Reply
Swagtron tech support offers to replace any battery if under warranty, which requires that you pay to ship the entire unit back to them for service. This seems insanely costly, but probably avoids voiding the warranty.
If you are out-of-warranty, they said they would sell me a battery, but did not offer any pricing info.
If you want to do-it-yourself, out-of-warranty: My guess it that the metal shielded “battery” actually contains commercially available LiIon cells which can be privately sourced, but may require some wire splicing, may be a shock hazard and such, so is more complex than just plug-in a replacement.
Chris Gray - Reply
What type of replacement battery is used for the Swagtron T1?
Swagtron wont give me the information!!
Maria Taylor - Reply
Past 24 Hours: 8
Past 7 Days: 24
Past 30 Days: 94
All Time: 13,712
