SwagTron T1 Gyroscope Replacement
  1. SwagTron T1 Gyroscope Replacement, Back Panels: step 1, image 1 of 1
    • Ensure that the SwagTron is off.
    • Turn the SwagTron upside down to see the underside.
  2. SwagTron T1 Gyroscope Replacement: step 2, image 1 of 3 SwagTron T1 Gyroscope Replacement: step 2, image 2 of 3 SwagTron T1 Gyroscope Replacement: step 2, image 3 of 3
    • Unscrew the eighteen 10mm screws that secure the back panels using a Phillips #2 screwdriver.
    • The screws are tightly in place. It will take effort to screw them out.
    • The panel is still attached to the SwagTron by wires that go to the motherboard.
    • Carefully lift the panels off
  3. SwagTron T1 Gyroscope Replacement: step 3, image 1 of 3 SwagTron T1 Gyroscope Replacement: step 3, image 2 of 3 SwagTron T1 Gyroscope Replacement: step 3, image 3 of 3
    • Follow the wires from the panels to the motherboard.
    • You may need to cut any zip ties that are holding the wires together.
    • There is one connection on the battery side and three on the other side that must be removed.
    • These connections may be difficult to remove. Try to securely press the connection and pull firmly.
    • Your back panels are now completely removed.
  4. SwagTron T1 Gyroscope Replacement, Gyroscope: step 4, image 1 of 2 SwagTron T1 Gyroscope Replacement, Gyroscope: step 4, image 2 of 2
    • Disconnect the gyroscope by disconnecting the wires attached to it. These wires are black, green, blue and red.
  5. SwagTron T1 Gyroscope Replacement: step 5, image 1 of 1
    • Using your Phillips #2 screwdriver, remove the four 8mm screws marked in red from the gyroscope.
  6. SwagTron T1 Gyroscope Replacement: step 6, image 1 of 3 SwagTron T1 Gyroscope Replacement: step 6, image 2 of 3 SwagTron T1 Gyroscope Replacement: step 6, image 3 of 3
    • Carefully remove the gyroscope component from the SwagTron.
9 other people completed this guide.
Teagan Allen
432 Reputation
2 Guides authored
Cal Poly, Team S17-G5, Banghart Spring 2017 Member of Cal Poly, Team S17-G5, Banghart Spring 2017
CPSU-BANGHART-S17S17G5
4 Members
5 Guides authored
5 Comments
I cannot find a Swagtron T1 replacement gyroscope anywhere on the internet. Any help would be extremely appreciated!! Thank you!
Gavin Hosler - Reply
Amazon.com Keyword: CertiCable
Jesse Griffis -
Where do you get the replacement?
Brittany Conner - Reply
Can’t find gyroscope for a t5 hover board please help.
jbswearingen70739 - Reply
I just got mine today and after the first hour I ran into a shoe and then I tried recalibrating it but it was no use. If someone knows what’s going on please tell me! Thank you :)
Elia Leon - Reply
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 22
All Time: 7,538
