SwagTron T1 Outer Shell Replacement
  1. SwagTron T1 Outer Shell Replacement, Back Panels: step 1, image 1 of 1
    • Ensure that the SwagTron is off.
    • Turn the SwagTron upside down to see the underside.
  2. SwagTron T1 Outer Shell Replacement: step 2, image 1 of 3 SwagTron T1 Outer Shell Replacement: step 2, image 2 of 3 SwagTron T1 Outer Shell Replacement: step 2, image 3 of 3
    • Unscrew the eighteen 10mm screws that secure the back panels using a Phillips #2 screwdriver.
    • The screws are tightly in place. It will take effort to screw them out.
    • The panel is still attached to the SwagTron by wires that go to the motherboard.
    • Carefully lift the panels off
  3. SwagTron T1 Outer Shell Replacement: step 3, image 1 of 3 SwagTron T1 Outer Shell Replacement: step 3, image 2 of 3 SwagTron T1 Outer Shell Replacement: step 3, image 3 of 3
    • Follow the wires from the panels to the motherboard.
    • You may need to cut any zip ties that are holding the wires together.
    • There is one connection on the battery side and three on the other side that must be removed.
    • These connections may be difficult to remove. Try to securely press the connection and pull firmly.
    • Your back panels are now completely removed.
  4. SwagTron T1 Outer Shell Replacement, Outer Shell: step 4, image 1 of 2 SwagTron T1 Outer Shell Replacement, Outer Shell: step 4, image 2 of 2
    • Unscrew the twelve 10mm screws that connect the metal chassis to the top plastic panel.
    • These screws will be low into the SwagTron.
  5. SwagTron T1 Outer Shell Replacement: step 5, image 1 of 1
    • Turn the SwagTron right side up and slightly lift up the panel.
    • Be careful to not pull too hard because the panel is still attached to the SwagTron by wires.
  6. SwagTron T1 Outer Shell Replacement: step 6, image 1 of 3 SwagTron T1 Outer Shell Replacement: step 6, image 2 of 3 SwagTron T1 Outer Shell Replacement: step 6, image 3 of 3
    • Turn the SwagTron over and disconnect the wires from the motherboard.
    • Follow the wires to the underside of the SwagTron.
    • Carefully remove the cord and the panel together.
    • All the panels are now free from the SwagTron.
Gloria Whang
185 Reputation
1 Guide authored
Cal Poly, Team S17-G5, Banghart Spring 2017 Member of Cal Poly, Team S17-G5, Banghart Spring 2017
CPSU-BANGHART-S17S17G5
4 Members
5 Guides authored
4 Guide Comments
Where did you ind a replacement shell for the Swagtron T1? I need to buy a new one, but can’t seem to find a place to buy it online.
Syd Jensen - Reply
Where can I buy a Swagtron T1 replacement shell?
Syd Jensen - Reply
Syd any luck finding a replacement shell?  I need to order the same kind and cannot find it online.
Craig -
Amazon.com Keyword: CertiCable
Jesse Griffis -
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 35
All Time: 2,203
