Swann Doorphone Video Intercom Camera Replacement
  1. Swann Doorphone Video Intercom Camera Replacement, Camera: step 1, image 1 of 3 Swann Doorphone Video Intercom Camera Replacement, Camera: step 1, image 2 of 3 Swann Doorphone Video Intercom Camera Replacement, Camera: step 1, image 3 of 3
    • Flip the outdoor camera over so that the underside is facing up.
    • Remove the back cover by grabbing the sides of the camera and pulling towards your body.
  2. Swann Doorphone Video Intercom Camera Replacement: step 2, image 1 of 2 Swann Doorphone Video Intercom Camera Replacement: step 2, image 2 of 2
    • With the back cover of the outdoor camera off, press the first gray button, with blue wire underneath, down as shown in the picture.
    • While pressing the gray square button, remove the blue wire from the first opening under the button.
    • Be sure to remove the same color wire for the outdoor camera as was used for the indoor video intercom.
  3. Swann Doorphone Video Intercom Camera Replacement: step 3, image 1 of 3 Swann Doorphone Video Intercom Camera Replacement: step 3, image 2 of 3 Swann Doorphone Video Intercom Camera Replacement: step 3, image 3 of 3
    • Remove the other wires using the same steps as the blue wire.
    • Using the JIS #0 screwdriver, remove the 2mm screws from the back plate.
    • Remove the back plate by pulling the plate away from the device.
  4. Swann Doorphone Video Intercom Camera Replacement: step 4, image 1 of 2 Swann Doorphone Video Intercom Camera Replacement: step 4, image 2 of 2
    • Using the JIS #0 screwdriver, remove the 1mm screws from behind the camera.
  5. Swann Doorphone Video Intercom Camera Replacement: step 5, image 1 of 2 Swann Doorphone Video Intercom Camera Replacement: step 5, image 2 of 2
    Tool used on this step:
    Buy
    • Using one of the tweezers from the Precision Tweezers Set, gently place them around the wire connector attached to the camera.
    • Pull slowly in the direction of the cables until the connector is no longer attached.
  6. Swann Doorphone Video Intercom Camera Replacement: step 6, image 1 of 2 Swann Doorphone Video Intercom Camera Replacement: step 6, image 2 of 2
    • Remove the camera from the device.
Emily Stenke
555 Reputation
4 Guides authored
USF Tampa, Team S2-G4, Eyestone Spring 2018 Member of USF Tampa, Team S2-G4, Eyestone Spring 2018
USFT-EYESTONE-S18S2G4
4 Members
5 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 696
