Swann Doorphone Video Intercom Microphone Replacement
  1. Swann Doorphone Video Intercom Microphone Replacement, Microphone: step 1, image 1 of 3 Swann Doorphone Video Intercom Microphone Replacement, Microphone: step 1, image 2 of 3 Swann Doorphone Video Intercom Microphone Replacement, Microphone: step 1, image 3 of 3
    • Flip the monitor of the Swann Doorphone Video Intercom over so that the underside is facing up.
    • Remove the six 2 mm corner screws from the back plate of the monitor using the JIS #0 screwdriver.
  2. Swann Doorphone Video Intercom Microphone Replacement: step 2, image 1 of 2 Swann Doorphone Video Intercom Microphone Replacement: step 2, image 2 of 2
    • Once the screws are removed, grip the black back plate of the monitor and remove from the monitor.
    • The back plate will still be connected to the monitor with a cord of wires that should not be removed.
  3. Swann Doorphone Video Intercom Microphone Replacement: step 3, image 1 of 3 Swann Doorphone Video Intercom Microphone Replacement: step 3, image 2 of 3 Swann Doorphone Video Intercom Microphone Replacement: step 3, image 3 of 3
    Tool used on this step:
    Buy
    • Using the precision tweezers, grab the sides of the white connector at the bottom of the green board.
    • Pull the white connector towards you to disconnect the board.
  4. Swann Doorphone Video Intercom Microphone Replacement: step 4, image 1 of 3 Swann Doorphone Video Intercom Microphone Replacement: step 4, image 2 of 3 Swann Doorphone Video Intercom Microphone Replacement: step 4, image 3 of 3
    • Grip the other end of the white connector cable towards the base of the black microphone.
    • Pull gently towards your body to remove the microphone.
Emily Stenke
555 Reputation
4 Guides authored
USF Tampa, Team S2-G4, Eyestone Spring 2018 Member of USF Tampa, Team S2-G4, Eyestone Spring 2018
USFT-EYESTONE-S18S2G4
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 15
All Time: 392
