Swann Wi-Fi Indoor Security Camera Microphone Replacement
  1. Swann Wi-Fi Indoor Security Camera Microphone Replacement, Case: step 1, image 1 of 3 Swann Wi-Fi Indoor Security Camera Microphone Replacement, Case: step 1, image 2 of 3 Swann Wi-Fi Indoor Security Camera Microphone Replacement, Case: step 1, image 3 of 3
    • Use the Phillips #0 to remove the screw located on the back of the camera above the mount.
    • Slide the mount out from the bottom of the device.
  2. Swann Wi-Fi Indoor Security Camera Microphone Replacement: step 2, image 1 of 1
    • Remove the back of the case by placing a iFixit opening tool underneath the edge of the case and prying it up.
  3. Swann Wi-Fi Indoor Security Camera Microphone Replacement: step 3, image 1 of 1
    • Carefully remove the back of the case without pulling the cables connected to the motherboard and the speaker on the back of the case.
  4. Swann Wi-Fi Indoor Security Camera Microphone Replacement, Microphone: step 4, image 1 of 3 Swann Wi-Fi Indoor Security Camera Microphone Replacement, Microphone: step 4, image 2 of 3 Swann Wi-Fi Indoor Security Camera Microphone Replacement, Microphone: step 4, image 3 of 3
    • Locate microphone and pull to dislodge from the holder.
    • Disconnect the connector located on the main board to finish disconnecting the microphone.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 776
