Swann Wi-Fi Indoor Security Camera SD Card Replacement
  1. Swann Wi-Fi Indoor Security Camera SD Card Replacement, Case: step 1, image 1 of 3 Swann Wi-Fi Indoor Security Camera SD Card Replacement, Case: step 1, image 2 of 3 Swann Wi-Fi Indoor Security Camera SD Card Replacement, Case: step 1, image 3 of 3
    • Use the Phillips #0 to remove the screw located on the back of the camera above the mount.
    • Slide the mount out from the bottom of the device.
  2. Swann Wi-Fi Indoor Security Camera SD Card Replacement: step 2, image 1 of 1
    • Remove the back of the case by placing a iFixit opening tool underneath the edge of the case and prying it up.
  3. Swann Wi-Fi Indoor Security Camera SD Card Replacement: step 3, image 1 of 1
    • Carefully remove the back of the case without pulling the cables connected to the motherboard and the speaker on the back of the case.
  4. Swann Wi-Fi Indoor Security Camera SD Card Replacement, SD Card: step 4, image 1 of 3 Swann Wi-Fi Indoor Security Camera SD Card Replacement, SD Card: step 4, image 2 of 3 Swann Wi-Fi Indoor Security Camera SD Card Replacement, SD Card: step 4, image 3 of 3
    • Facing the front of the camera, remove the four 2.0 mm Phillips #0 black screws that hold the back of the motherboard to the case.
  5. Swann Wi-Fi Indoor Security Camera SD Card Replacement: step 5, image 1 of 1
    • With the motherboard removed, flip it over and remove the SD card by pushing in the SD card, releasing it.
0 Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 28
All Time: 1,309
