Swann Wi-Fi Indoor Security Camera-Camera Lens Replacement
  1. Swann Wi-Fi Indoor Security Camera-Camera Lens Replacement, Case: step 1, image 1 of 3 Swann Wi-Fi Indoor Security Camera-Camera Lens Replacement, Case: step 1, image 2 of 3 Swann Wi-Fi Indoor Security Camera-Camera Lens Replacement, Case: step 1, image 3 of 3
    • Use the Phillips #0 to remove the screw located on the back of the camera above the mount.
    • Slide the mount out from the bottom of the device.
  2. Swann Wi-Fi Indoor Security Camera-Camera Lens Replacement: step 2, image 1 of 1
    • Remove the back of the case by placing a iFixit opening tool underneath the edge of the case and prying it up.
  3. Swann Wi-Fi Indoor Security Camera-Camera Lens Replacement: step 3, image 1 of 1
    • Carefully remove the back of the case without pulling the cables connected to the motherboard and the speaker on the back of the case.
  4. Swann Wi-Fi Indoor Security Camera-Camera Lens Replacement, Camera Lens: step 4, image 1 of 2 Swann Wi-Fi Indoor Security Camera-Camera Lens Replacement, Camera Lens: step 4, image 2 of 2
    • Facing the front of the camera, remove the four 2.0 mm Phillips #0 black screws that hold the back of the motherboard to the case.
    • Release the four camera cable connections on the motherboard.
  5. Swann Wi-Fi Indoor Security Camera-Camera Lens Replacement: step 5, image 1 of 1
    • Facing the back of the motherboard, remove the two 2.0 mm Phillips #0 screws connecting the camera to the motherboard.
One Comment
is there a place i can buy a replacement lens for my swann security camera please
sn 10050062001244
Sonny Jobe - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 24
All Time: 1,134
