SweetLF SW7105 Battery Replacement
  1. SweetLF SW7105 Battery Replacement, Clean and dry the unit: step 1, image 1 of 1
    • Ensure the device is clean an dry before starting
  2. SweetLF SW7105 Battery Replacement, Remove the case screws: step 2, image 1 of 3 SweetLF SW7105 Battery Replacement, Remove the case screws: step 2, image 2 of 3 SweetLF SW7105 Battery Replacement, Remove the case screws: step 2, image 3 of 3
    • Remove the three T6 Torex screens in the positions highlighted. Two inside the shaver head, one on the outside back.
  3. SweetLF SW7105 Battery Replacement, Remove the outer cover: step 3, image 1 of 1
    • Gently pry open the case to pop the front blue cover off. There are three catch points on each side. (Suggest to start working down the side from the top, be careful not to snap any of the holding points as you lift them open)
    • Once the front cover is released, the back will easily fall away
  4. SweetLF SW7105 Battery Replacement, Remove the circuits waterproof cover: step 4, image 1 of 1
    • Gently pop off the white cover which is protecting the electronics.
  5. SweetLF SW7105 Battery Replacement, Remove the circuit board from the case: step 5, image 1 of 2 SweetLF SW7105 Battery Replacement, Remove the circuit board from the case: step 5, image 2 of 2
    • De-seolder the points highlighted (the charging / power supply pegs) and gently lift/pull out the electronics.
    • The unit is held in by the charging pegs and also with double sided tape on the back of the battery, so may need some gentle force/working at to lift (once the charging pegs have been de-soldered to free them).
    • N. B. the wires to the motors remain attached so do not fully tear away.
  6. SweetLF SW7105 Battery Replacement, Remove the original battery: step 6, image 1 of 1
    • De-solder at the points highlighted to release the battery from the circuit board.
  7. SweetLF SW7105 Battery Replacement, Install replacement battery: step 7, image 1 of 1
    • Solder the replacement battery back in place. Note which end has the positive (closest to the shaving head), usually this can be identified by a small ridge/dip on the battery case (if not clearly marked)
    • Replacement battery must be of the same voltage, although the capacity my be larger if needed.
    • You may need to trim (using scissors) the solder tags on the battery to make them narrow enough to fit through the holes in the PCB / circuit board
    • Follow the steps in reverse & the battery function should be restored better than before!
2 other people completed this guide.
Andrew
227 Reputation
1 Guide authored
3 Guide Comments
Very Useful,
Regards,M.Lawlor
M.J. Lawlor - Reply
Thank you! Very useful.
jimbo585 - Reply
Very well explained although I van not undwrstand tge reason why they build a project which it is almost impossible to be sucssesfull. There must be a way to build an easier way to replace the battery
Tel Braz - Reply
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 85
All Time: 1,801
