Swimming Pool Diving Board Replacement
  1. Swimming Pool Diving Board Replacement, Diving Board: step 1, image 1 of 3 Swimming Pool Diving Board Replacement, Diving Board: step 1, image 2 of 3 Swimming Pool Diving Board Replacement, Diving Board: step 1, image 3 of 3
    • Using a ratchet, 5/16" Allen hex socket, and 3/4" box wrench, unscrew the fastener where the diving board meets the top of the spring.
  2. Swimming Pool Diving Board Replacement: step 2, image 1 of 3 Swimming Pool Diving Board Replacement: step 2, image 2 of 3 Swimming Pool Diving Board Replacement: step 2, image 3 of 3
    • Use a ratchet and 15/16" short socket to unthread the 4 hex head fasteners from the fiber glass base.
  3. Swimming Pool Diving Board Replacement: step 3, image 1 of 3 Swimming Pool Diving Board Replacement: step 3, image 2 of 3 Swimming Pool Diving Board Replacement: step 3, image 3 of 3
    • After 4 nylock hex head fasteners have been removed, lift the fiber glass base from the 4 threaded studs that are protruding from the concrete.
  4. Swimming Pool Diving Board Replacement: step 4, image 1 of 3 Swimming Pool Diving Board Replacement: step 4, image 2 of 3 Swimming Pool Diving Board Replacement: step 4, image 3 of 3
    • Remove 2 fasteners where the diving board meets the fiber glass base using the 5/16" Allen hex socket and the 3/4" hex nylock nut.
    • Set the base and board on a stable elevated surface like a table to make it easy to access the parts under the base.
  5. Swimming Pool Diving Board Replacement: step 5, image 1 of 3 Swimming Pool Diving Board Replacement: step 5, image 2 of 3 Swimming Pool Diving Board Replacement: step 5, image 3 of 3
    • To attach the new diving board, fasten the fiber glass base to the diving board using button head bolts, washers, gaskets, and nylock nuts.
    • Do not fasten the board to the fiber glass base too tightly as jumping on it while it is too tight can overload the diving board.
  6. Swimming Pool Diving Board Replacement: step 6, image 1 of 2 Swimming Pool Diving Board Replacement: step 6, image 2 of 2
    • Mount the base with the new diving board back onto the 4 threaded studs protruding from the ground.
  7. Swimming Pool Diving Board Replacement: step 7, image 1 of 3 Swimming Pool Diving Board Replacement: step 7, image 2 of 3 Swimming Pool Diving Board Replacement: step 7, image 3 of 3
    • Thread the 15/16" nylock nuts and washers onto stud anchors.
  8. Swimming Pool Diving Board Replacement: step 8, image 1 of 3 Swimming Pool Diving Board Replacement: step 8, image 2 of 3 Swimming Pool Diving Board Replacement: step 8, image 3 of 3
    • Using a ratchet, 5/16" Allen hex socket, and 3/4" box wrench, screw on the fastener where the diving board meets the top of the spring.
Now that you have replaced your diving board, make sure to test it out! That spring will give you a greater bounce than a traditional diving board!
Michael Rodriguez
157 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 16
All Time: 730
