Synology DS1019+ - a complete disassembly in rules
  1. Synology DS1019+ - a complete disassembly in rules, Presentation: the different faces of the case: step 1, image 1 of 3 Synology DS1019+ - a complete disassembly in rules, Presentation: the different faces of the case: step 1, image 2 of 3 Synology DS1019+ - a complete disassembly in rules, Presentation: the different faces of the case: step 1, image 3 of 3
    • Here are the different interesting faces of the case: front (bay disks), rear (connectors and fans), below (2 hatches SSD).
    • This NAS DS1019+ is equipped with 8 GB of memory, an INTEL Celeron J3455 64-bit Quad processor, five bays for SATA drives.
    • FRONT : disk cage lock / REAR : Kensington security incision (K-lock)
    • 2 USB 3 ports (1 in front and 1 behind)
    • 2 x RJ45 Gb ports.
    • FRONT : 1 port for power supply
    • BELOW : 2 M.2 NVMe 2280 ports (disk cache)
    • REAR : 1 eSATA port
  2. Synology DS1019+ - a complete disassembly in rules, Unlock the disk media: step 2, image 1 of 1
    • Before teardown, unlock the disk media with the key.
  3. Synology DS1019+ - a complete disassembly in rules, Removes disks from the bay: step 3, image 1 of 2 Synology DS1019+ - a complete disassembly in rules, Removes disks from the bay: step 3, image 2 of 2
    • Since the media are unlocked, remove each disk media.
  4. Synology DS1019+ - a complete disassembly in rules, Backplane and memory slot access: step 4, image 1 of 3 Synology DS1019+ - a complete disassembly in rules, Backplane and memory slot access: step 4, image 2 of 3 Synology DS1019+ - a complete disassembly in rules, Backplane and memory slot access: step 4, image 3 of 3
    • This is a significant innovation, the memory is now directly accessible and without disassembly of the housing, for the original bar as for the extension port.
    • backplane with 5 SATA connectors
    • 2 memory slots
  5. Synology DS1019+ - a complete disassembly in rules, Housing: hood removal 1/2: step 5, image 1 of 1
    • Remove the 2 screws on the back of the case at the top and bottom (not the one above the USB port)
  6. Synology DS1019+ - a complete disassembly in rules, Housing: hood removal 2/2: step 6, image 1 of 3 Synology DS1019+ - a complete disassembly in rules, Housing: hood removal 2/2: step 6, image 2 of 3 Synology DS1019+ - a complete disassembly in rules, Housing: hood removal 2/2: step 6, image 3 of 3
    • Slide the cover forward, then slide it out (here, to the left).
  7. Synology DS1019+ - a complete disassembly in rules, Internal parts: presentation: step 7, image 1 of 3 Synology DS1019+ - a complete disassembly in rules, Internal parts: presentation: step 7, image 2 of 3 Synology DS1019+ - a complete disassembly in rules, Internal parts: presentation: step 7, image 3 of 3
    • in red: SSD M.2 expansion card 2280
    • in yellow: USB 3 port
    • in orange: internal connectors of the 2 fans
    • in green: 2 slots of RAM
    • in blue: SATA III backplane (5 hard drive bays)
    • in pink: fixing the fans on the chassis
    • 3-PIN connectors of the fans
  8. Synology DS1019+ - a complete disassembly in rules, USB 3 port removal: step 8, image 1 of 2 Synology DS1019+ - a complete disassembly in rules, USB 3 port removal: step 8, image 2 of 2
    • Insérez ici votre traduction
    • Remove the 2 screws from the holding plate of the USB connector 3 and on the rear side.
    • Then remove the USB3 metal plate.
    • Removal of the SSD M2 board is not necessary for motherboard disassembly.
    • Do not remove the USB connector 3 on the motherboard, it is glued. It does not interfere with disassembly!
  9. Synology DS1019+ - a complete disassembly in rules, Removing fan clips: step 9, image 1 of 3 Synology DS1019+ - a complete disassembly in rules, Removing fan clips: step 9, image 2 of 3 Synology DS1019+ - a complete disassembly in rules, Removing fan clips: step 9, image 3 of 3
    • Remove the screws from the two shims to secure the disc cage and the two fans.
    • These plastic spacers are keyed
  10. Synology DS1019+ - a complete disassembly in rules, Remove motherboard from the hood 1/2: step 10, image 1 of 3 Synology DS1019+ - a complete disassembly in rules, Remove motherboard from the hood 1/2: step 10, image 2 of 3 Synology DS1019+ - a complete disassembly in rules, Remove motherboard from the hood 1/2: step 10, image 3 of 3
    • 4 Phillips screws must be removed from two side.
    • Remove the fans's 3-PIN power cable
  11. Synology DS1019+ - a complete disassembly in rules, Remove motherboard from the hood 2/2: step 11, image 1 of 2 Synology DS1019+ - a complete disassembly in rules, Remove motherboard from the hood 2/2: step 11, image 2 of 2
    • Here, the motherboard is still secure to the disk cage.
    • Remove the motherboard from the case paying attention to the USB 3 connector on the front and the power button. To do this, move the front panel a little and lift the motherboard upwards (outside).
    • Take care.
  12. Synology DS1019+ - a complete disassembly in rules, Unsecure the motherboard from the metal cover: step 12, image 1 of 3 Synology DS1019+ - a complete disassembly in rules, Unsecure the motherboard from the metal cover: step 12, image 2 of 3 Synology DS1019+ - a complete disassembly in rules, Unsecure the motherboard from the metal cover: step 12, image 3 of 3
    • Once the motherboard is out, unscrew the 4 screws of the metal protective cover (metal plate).
  13. Synology DS1019+ - a complete disassembly in rules, Motherboard: processor side: step 13, image 1 of 1
    • Motherboard processor side
    • INTEL Celeron J3455 / 64-bit / Quad core 1.5 burst up to 2.3 GHz
    • Memory battery
    • Internal beep
    • USB 3 port
    • Power button
    • Flash memory
  14. Synology DS1019+ - a complete disassembly in rules, Motherboard: memory side: step 14, image 1 of 1
    • Memory side of the motherboard (pre-equipped with 8 GB of RAM)
    • NVMe M.2 SSD expansion card connector
    • Connector (PCIe ??) for SATA disk expansion card
    • Fan connector (x2)
    • Power connector
    • RJ45 LAN Connector x2
    • eSATA connector
    • 2 x 4GB DDR3L 1866 RAM Memory Stick
To reassemble your device, follow the instructions in reverse order.
4 other people completed this guide.
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Attached Documents
Sébastien
4,060 Reputation
6 Guides authored
AEM (ANIMA EX MACHINA) Member of AEM (ANIMA EX MACHINA)
Business
1 Member
14 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 76
All Time: 3,105
