Synology DiskStation DS412+ RAM Replacement
  1. Synology DiskStation DS412+ RAM Replacement, DS412+: step 1, image 1 of 2 Synology DiskStation DS412+ RAM Replacement, DS412+: step 1, image 2 of 2
    • DS412+
    • Remove the front panel
  2. Synology DiskStation DS412+ RAM Replacement: step 2, image 1 of 1
    • Remove the hard disks
  3. Synology DiskStation DS412+ RAM Replacement: step 3, image 1 of 2 Synology DiskStation DS412+ RAM Replacement: step 3, image 2 of 2
    • Remove the two screws in the back of the NAS, on the top and bottom.
  4. Synology DiskStation DS412+ RAM Replacement: step 4, image 1 of 2 Synology DiskStation DS412+ RAM Replacement: step 4, image 2 of 2
    • Locate those 2 tabs on the left side inside the device.
    • Lift them up off the metal brace
    • You may have to bend the metal support bar to remove the case. Bend it back if you do.
  5. Synology DiskStation DS412+ RAM Replacement: step 5, image 1 of 2 Synology DiskStation DS412+ RAM Replacement: step 5, image 2 of 2
    • Push the case away towards the back about 1 cm
  6. Synology DiskStation DS412+ RAM Replacement: step 6, image 1 of 2 Synology DiskStation DS412+ RAM Replacement: step 6, image 2 of 2
    • With the NAS on its right side, lift up the enclosure, mind the tabs on the top of the case.
  7. Synology DiskStation DS412+ RAM Replacement: step 7, image 1 of 2 Synology DiskStation DS412+ RAM Replacement: step 7, image 2 of 2
    • Remove the screw securing the HDD bays enclosure.
  8. Synology DiskStation DS412+ RAM Replacement: step 8, image 1 of 1
    • Remove the screw securing the I/O board.
  9. Synology DiskStation DS412+ RAM Replacement: step 9, image 1 of 2 Synology DiskStation DS412+ RAM Replacement: step 9, image 2 of 2
    • Remove the four screws securing the HDD bays
  10. Synology DiskStation DS412+ RAM Replacement: step 10, image 1 of 2 Synology DiskStation DS412+ RAM Replacement: step 10, image 2 of 2
    • Pull the fan a little bit away
  11. Synology DiskStation DS412+ RAM Replacement: step 11, image 1 of 2 Synology DiskStation DS412+ RAM Replacement: step 11, image 2 of 2
    • Watch out for this plug
    • Lift the metal bracket out
  12. Synology DiskStation DS412+ RAM Replacement: step 12, image 1 of 2 Synology DiskStation DS412+ RAM Replacement: step 12, image 2 of 2
    • Remove the fan power headers
  13. Synology DiskStation DS412+ RAM Replacement: step 13, image 1 of 1
    • Remove the I/O board by lifting it up
  14. Synology DiskStation DS412+ RAM Replacement: step 14, image 1 of 2 Synology DiskStation DS412+ RAM Replacement: step 14, image 2 of 2
    • Remove those 4 screws
  15. Synology DiskStation DS412+ RAM Replacement: step 15, image 1 of 1
    • Starting from the front of the unit, remove the motherboard from the unit.
  16. Synology DiskStation DS412+ RAM Replacement: step 16, image 1 of 3 Synology DiskStation DS412+ RAM Replacement: step 16, image 2 of 3 Synology DiskStation DS412+ RAM Replacement: step 16, image 3 of 3
    • Pull these tabs and remove the ram
    • Old and new Ram
    • The old RAM's part number is: M3SN-1GSFCCM7-GA14
    • To reassemble your device, follow these instructions in reverse order.
35 other people completed this guide.
gieljnssns
981 Reputation
1 Guide authored
19 Guide Comments
Hi is it also possible with a Synology ds216play? Or is the RAM not modular in this Drives?
markusguenther30684 - Reply
Very nice guide. Thank you!
mbs - Reply
Thank you for the guide, just to ease it up a bit for everybody following, the best way to pull the two tabs from step 4 was to use small spoon (or anything metal) and use it as a crowbar from the inside (do not try to put force from the outer rim, but really from inside of the Synology itself (against the metal beam the tabs are holding to).
Ondrej Palat - Reply
Thank you very much.
Olivier Claude - Reply
did these steps and now my DS412+ won't boot anymore. just the blue power light for a few seconds, no hard drive or fan will turn on.
after putting the old RAM in the slot nothing changed. cannot find any error, how do I find out what's wrong here???
Andreas Hanny - Reply
Past 24 Hours: 20
Past 7 Days: 77
Past 30 Days: 291
All Time: 28,578
