TCA PRC 152A Disassembly
  1. TCA PRC 152A Disassembly, Prepare the radio for dissasembly: step 1, image 1 of 1
    • Remove antenna and battery before dissasembly
    • Prepare the tools before starting We'll start with the radio and then the accessories...
  2. TCA PRC 152A Disassembly, Removing the backpannel: step 2, image 1 of 3 TCA PRC 152A Disassembly, Removing the backpannel: step 2, image 2 of 3 TCA PRC 152A Disassembly, Removing the backpannel: step 2, image 3 of 3
    • Remove 4 screws on the backpannel
    • Phillips PH3
    • The small retention piece is held by the screw. Be careful not to lose the spring
  3. TCA PRC 152A Disassembly, Removing the backpanel: step 3, image 1 of 2 TCA PRC 152A Disassembly, Removing the backpanel: step 3, image 2 of 2
    • Carefully open the rear panel with the opener's plastic tool.
    • You can see the connection map of the different terminals.
    • GPS option (Does not work)
    • PTT and config button socket
    • U283 6PIN connector
    • ON/OFF/Volume knob
    • Side connector (Does not work)
  4. TCA PRC 152A Disassembly, Removing frontpannel: step 4, image 1 of 3 TCA PRC 152A Disassembly, Removing frontpannel: step 4, image 2 of 3 TCA PRC 152A Disassembly, Removing frontpannel: step 4, image 3 of 3
    • Carefully open the front panel with the opener's plastic tool.
    • Microphone attached to the PCB board (1.080KOhm).Can be replaced by POW-2744P-B-R
    • Speaker FCE 16Ohm 1Watt.
    • Beware of silicone for the sealing of the elements.
  5. TCA PRC 152A Disassembly, Frontpannel microphone removal: step 5, image 1 of 3 TCA PRC 152A Disassembly, Frontpannel microphone removal: step 5, image 2 of 3 TCA PRC 152A Disassembly, Frontpannel microphone removal: step 5, image 3 of 3
    • Remove 1 screw
    • Phillips PH1
    • Carefully remove withe the plastic tool
  6. TCA PRC 152A Disassembly, Display and keyboard front card: step 6, image 1 of 3 TCA PRC 152A Disassembly, Display and keyboard front card: step 6, image 2 of 3 TCA PRC 152A Disassembly, Display and keyboard front card: step 6, image 3 of 3
    • Remove 4 screws
    • Phillips PH2
    • Disconnect the flat connector
    • Use caution when you remove the flat connector
  7. TCA PRC 152A Disassembly, Display and keyboard front card: step 7, image 1 of 2 TCA PRC 152A Disassembly, Display and keyboard front card: step 7, image 2 of 2
    • Place the electronics elements on ESD bags
  8. TCA PRC 152A Disassembly, Peripheral back card: step 8, image 1 of 3 TCA PRC 152A Disassembly, Peripheral back card: step 8, image 2 of 3 TCA PRC 152A Disassembly, Peripheral back card: step 8, image 3 of 3
    • Disconnect 2 JSP connectors and 2 flat connector
    • Remove 4 screws
    • Phillips PH2
    • Carefully disconect the connectors and the board
  9. TCA PRC 152A Disassembly, Mainboard removal: step 9, image 1 of 3 TCA PRC 152A Disassembly, Mainboard removal: step 9, image 2 of 3 TCA PRC 152A Disassembly, Mainboard removal: step 9, image 3 of 3
    • Remove 4 screws
    • Phillips PH2
    • Disconnect the antenna connector
    • Carefully removing the mainboard
    • Thermal paste between the card and the body
  10. TCA PRC 152A Disassembly, Side connectors removal: step 10, image 1 of 2 TCA PRC 152A Disassembly, Side connectors removal: step 10, image 2 of 2
    • Remove 2 screws
    • Phillips PH1
    • Carefully removing the connector
  11. TCA PRC 152A Disassembly, Batterybloc dissasembly: step 11, image 1 of 3 TCA PRC 152A Disassembly, Batterybloc dissasembly: step 11, image 2 of 3 TCA PRC 152A Disassembly, Batterybloc dissasembly: step 11, image 3 of 3
    • Remove 2 screws
    • Phillips PH3
    • Remove the topcover, take care about short circuit
  12. TCA PRC 152A Disassembly, Batterybloc dissasembly: step 12, image 1 of 3 TCA PRC 152A Disassembly, Batterybloc dissasembly: step 12, image 2 of 3 TCA PRC 152A Disassembly, Batterybloc dissasembly: step 12, image 3 of 3
    • Remove battery stick (18650 Panasonic)
    • Remove 2 screws
    • Phillips PH3
    • Take off the inner white retainer
Finish Line
3 other people completed this guide.
Tomazo_88
439 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 28
Past 30 Days: 109
All Time: 4,396
