TCL Stylus Battery Replacement
Lee Hunt
Lee Hunt and one other contributor
Last updated on May 5, 2023
7 - 10 minutes
Moderate
Bullets!
Community-Contributed Guide
Introduction
Go to step 1
This is how to replace the battery on a TCL Stylus 5G.
Parts
Tools
Show more…
    • Press and hold the Power button for 2 seconds.
    • Then, select "Power off".
  1. TCL Stylus Battery Replacement, Remove back panel: step 2, image 1 of 3 TCL Stylus Battery Replacement, Remove back panel: step 2, image 2 of 3 TCL Stylus Battery Replacement, Remove back panel: step 2, image 3 of 3
    • Insert a jimmy tool into the casing to create a gap.
    • Then, put a plastic pick in the gap and remove the jimmy tool.
    • Finally, lift up to remove the panel.
  2. TCL Stylus Battery Replacement, Remove plastic shielding: step 3, image 1 of 2 TCL Stylus Battery Replacement, Remove plastic shielding: step 3, image 2 of 2
    • Remove the 10 Phillips screws holding the plastic shielding from the motherboard.
    • Then, grab a pick and put in in the slot show on picture 2.
    • You should then be able to lift the rest of it off.
  3. TCL Stylus Battery Replacement, Unplug battery: step 4, image 1 of 2 TCL Stylus Battery Replacement, Unplug battery: step 4, image 2 of 2
    • With your fingernail, lift up the battery connector.
  4. TCL Stylus Battery Replacement, Unpeel tape: step 5, image 1 of 2 TCL Stylus Battery Replacement, Unpeel tape: step 5, image 2 of 2
    • Unpeel the tape holding the battery.
  5. TCL Stylus Battery Replacement, Remove battery: step 6, image 1 of 2 TCL Stylus Battery Replacement, Remove battery: step 6, image 2 of 2
    • Pull on the sticker located on the middle of the left side (colored green) of the battery to remove it.
    • NOTE: The pull tab may have resistance.
Lee Hunt
1,076 Reputation
6 Guides authored
5 Comments
Lg syluis is a non removeable battery
katherine hicks - Reply
It's just not easily removable. But every battery in every phone is removable if you know what you're doing. That's why the pictures explain. You come in here getting all worked up but your ignorance really shows. Obviously you don't have the intelligence to attempt this kind of repair, so go crochet me some mittens or something.
Cj Gabbard -
Its a non removeable battery phone,unless u control it with a chiness &&^&@@ dumb ass move battery
Thanks for the information. At least you do not have to deal with heating the phone in order to loosen adhesive which is common with other phone models. Six steps to get to the battery is way easier than going through over 20 steps to do the same thing.
e s - Reply
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 37
All Time: 1,881
